File not found Hyper V to VMware
istsupport
Thu Jun 13, 2024 3:55 pm
We are trying to convert + migrate from a HyperV cluster environment to a VMWare VXRail cluster environment. Once the conversion and migration starts, it gives "file not found" errors, and fails, see logs below:
6/13 10:20:33.658 4f01c Facility ???INFO: ESXVmdk::ParseFile: sFilename - [VxRail-Virtual-SAN-Datastore-66e5d8cc-b932-4de2-a815-ec1be9c9eaf7] Casa2016-172.17.3.100/CASA2016-172.17.3.100.vmdk
6/13 10:20:33.658 4f01c Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=vm-2013
6/13 10:20:33.714 4f01c Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 7C:10:E7:DA:B7:0E:B8:24:78:A3:48:1A:B0:CC:FA:2B:00:54:F9:79
6/13 10:20:34.318 4f01c Facility ???ERROR: ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 4, A file was not found
6/13 10:20:34.318 4f01c Facility ???ERROR: ESXIDisk::CreateOutputImage: ParseFile is fail
6/13 10:20:34.318 4f01c Facility ???INFO: CPPConverting::ConvertDisks: CreateOutputImage: 1
6/13 10:20:34.319 4f01c Facility ???ERROR: CPPConverting::Convert: FAILED
Thu Jun 13, 2024 5:02 pm
Welcome to StarWind Forum.
Please convert the files, and copy them to VXRail.
istsupport
Thu Jun 13, 2024 6:11 pm
Thanks for the reply. So you mean convert the VHD files and then attach them to VXRail? Will we still be able to use the VM migration tool to transfer the VM itself and then just attach the converted VMDK?
Thu Jun 13, 2024 6:49 pm
You are always welcome.
Yes, but will be easier to copy the converted file from Hyper-V to VXRail.
istsupport
Thu Jun 13, 2024 7:23 pm
So the V2V tool will not work to auto convert / migrate from a Hyper V cluster into a VX Rail cluster?
Thu Jun 13, 2024 8:00 pm
Can you please describe in detail the conversion scenario that you captured in the log and share the entire conversion log?
