VivBurrows
Mon Apr 08, 2024 7:33 am
Is it possible to use the converter to create the required files for XCP-NG?
We're moving from ESXi after a very long time
billallaire
Mon May 13, 2024 5:44 pm
I'm new here but I am doing the same for a home lab. If you export the VM from ESXi to an OVA or OVF I have used the Orchestra product to import it. I recently used this to import OVA's from Bitnami, but don't see any reason why it wouldn't work with exported VM's from ESXi. Hope this helps.
