Access is Denied - P2V Server 2022 Hyper-V
Chrisrip
Tue Jan 23, 2024 11:15 am
Hi gurus.
I am stuck. Here is my scenario.
Physical IBM x3400 M3 server with SCSI RAID, 3 Disk Partitions. MS SBS 2011 with AD and an SQL application that I need to virtualise then remove SBS apps and AD.
New server is running Windows Server 2022 Standard with Hyper-V. Not joined to existing domain.
I run SW V2V on SBS server and select P2V > Entire Machine > Select all volumes > Select Microsoft Hyper-V Server > enter host credentials ie. hostname, hostname\administrator, password.
I get error "Access is denied. 0x80070005"
What am I missing or this an unsupported scenario?
Thanks in advance.
sc2111
Tue Jan 23, 2024 11:51 am
I've the same issue here with hyper-v 2016
Tue Jan 23, 2024 12:06 pm
Welcome to StarWind Forum
Speaking of the Small Business Server incident, is the OS it is running on?
Please tell me more about the Hyper-V 2016 incident. Is it the GUI-less version? Can you please try CLI for P2V?
sc2111
Tue Jan 23, 2024 1:00 pm
Hello
I've the same access denied error with windows 2019 Datacenter edition
thanks
Tue Jan 23, 2024 1:55 pm
That's interesting. Thanks for the extra test and ideas.
Can you please create a fresh install of a Windows VM on any of those hosts and try running P2V conversion inside that VM?
Chrisrip
Tue Jan 23, 2024 10:40 pm
yaroslav (staff) wrote:Welcome to StarWind Forum
The physical machine is running Server 2008 R2 with Small Business Server suite but the exchange & sharepoint services have been removed. It is still running AD & SQL though.
Tue Jan 23, 2024 11:12 pm
Thanks for your update.
Is it x64 or x86 one?
Chrisrip
Wed Jan 24, 2024 1:49 am
yaroslav (staff) wrote:Thanks for your update.
X64
Fri Jan 26, 2024 8:51 pm
Sorry for the delay. Could you please try running the software as an administrator?
Chrisrip
Tue Feb 06, 2024 6:03 am
yaroslav (staff) wrote:Sorry for the delay. Could you please try running the software as an administrator?
Update since last time. On the Server 2019 Hyper-V event viewer I could see there was a warning relating to the physical host attempting to authnticate using NTLM (as it is a Server 2008 machine) and it was being declined so I created a separate OU for the hyper-v host and created a GP to exclude the hyper-v server from NTLM restictions.
Now I get the error "The RPC server is unavailable. (0x800706ba)
I ran ad administrator without any difference, but we are a little closer.
Tue Feb 06, 2024 8:23 am
Thanks for your update. The RPC server error is not likely to be related to StarWind VSAN. It seems to be something within the domain or certificates.
Check this out https://productsupport.red-gate.com/hc/ ... e%20server.
https://learn.microsoft.com/en-us/troub ... enrollment
