VMware to Hyper-V migration failing, error 14009
dwindheim
Sat Dec 17, 2022 4:16 am
Getting an error that says "server refused connection" even after disabling firewall on Hyper-V host
It'll convert for a while, then eventually crash. I can hit "retry" and it'll get 1% or 2% further then give me the same error, logs below:
The log file name: 'logs\V2V_Log-20221216-185322.log' (PID 4452)
12/16 18:53:22.009 2f1c Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
12/16 18:53:22.009 2f1c Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.268
12/16 18:53:22.025 2f1c Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
12/16 18:53:22.025 2f1c Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
12/16 18:53:22.025 2f1c Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 20348
12/16 18:53:22.025 2f1c Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 743a0000
12/16 18:53:32.369 2f1c Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
12/16 18:53:46.444 2f1c Facility ???INFO: WrapperESXI::connect: m_url - https://172.16.1.3/sdk
12/16 18:53:46.491 2f1c Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - 52287fcb-9243-ba30-0a30-007cfb4c57ad
12/16 18:53:46.506 2f1c Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
12/16 18:53:46.601 2f1c Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 6.7.0
12/16 18:53:53.221 2f1c Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
12/16 19:06:27.598 2f1c Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eFormat
12/16 19:06:34.308 2f1c Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOptionsHyperV
12/16 19:06:49.300 2f1c Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOutputFile
12/16 19:07:22.373 2f1c Facility ???INFO: CPPOutputFile::onNext: Out path: D:\Hyper-V\Docuware2\Virtual Hard Disks\Docuware2-000002.vhdx, Out format 11
12/16 19:07:22.373 2f1c Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
12/16 19:07:22.378 1138 Facility ???INFO: CPPConverting::Convert: InConvertType: 5, OutConvertType: 4
12/16 19:07:22.378 1138 Facility ???INFO: CPPConverting::ConvertImage: pathInput: [InternalRaid] Docuware2/Docuware2-000002.vmdk, pathOutput: D:\Hyper-V\Docuware2\Virtual Hard Disks\Docuware2-000002.vhdx
12/16 19:07:22.405 1138 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [InternalRaid] Docuware2/Docuware2-000002.vmdk
12/16 19:07:22.405 1138 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=4
12/16 19:07:22.414 1138 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 9C:3E:0B:F8:9C:26:ED:38:66:DD:84:B5:06:0E:48:78:FB:EB:AC:08
12/16 19:07:27.411 1138 Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
12/16 19:11:24.693 1138 Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 0
12/16 19:27:40.424 1138 Facility ???ERROR: VMwareFile::Read: m_VixDiskLib_Read is fail - 14009, The server refused connection
12/16 19:27:40.424 1138 Facility ???ERROR: CPPConverting::ConvertImage: Read 3
12/16 19:38:35.749 1138 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [InternalRaid] Docuware2/Docuware2-000002.vmdk
12/16 19:38:35.749 1138 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=4
12/16 19:38:35.749 1138 Facility ???INFO: ESXVmdk::ParseFile: Close disk
12/16 19:38:35.749 1138 Facility ???INFO: ESXVmdk::ParseFile: Disconnect
12/16 19:38:42.761 1138 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 9C:3E:0B:F8:9C:26:ED:38:66:DD:84:B5:06:0E:48:78:FB:EB:AC:08
12/16 19:44:45.460 1138 Facility ???ERROR: VMwareFile::Read: m_VixDiskLib_Read is fail - 14009, The server refused connection
12/16 19:44:45.460 1138 Facility ???ERROR: CPPConverting::ConvertImage: Read 3
12/16 19:47:42.438 1138 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [InternalRaid] Docuware2/Docuware2-000002.vmdk
12/16 19:47:42.438 1138 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=4
12/16 19:47:42.438 1138 Facility ???INFO: ESXVmdk::ParseFile: Close disk
12/16 19:47:42.438 1138 Facility ???INFO: ESXVmdk::ParseFile: Disconnect
12/16 19:47:42.448 1138 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 9C:3E:0B:F8:9C:26:ED:38:66:DD:84:B5:06:0E:48:78:FB:EB:AC:08
12/16 19:58:15.355 1138 Facility ???ERROR: VMwareFile::Read: m_VixDiskLib_Read is fail - 14009, The server refused connection
12/16 19:58:15.355 1138 Facility ???ERROR: CPPConverting::ConvertImage: Read 3
12/16 19:58:18.996 1138 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [InternalRaid] Docuware2/Docuware2-000002.vmdk
12/16 19:58:18.996 1138 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=4
12/16 19:58:18.996 1138 Facility ???INFO: ESXVmdk::ParseFile: Close disk
12/16 19:58:18.996 1138 Facility ???INFO: ESXVmdk::ParseFile: Disconnect
12/16 19:58:19.074 1138 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 9C:3E:0B:F8:9C:26:ED:38:66:DD:84:B5:06:0E:48:78:FB:EB:AC:08
12/16 20:06:02.025 1138 Facility ???ERROR: VMwareFile::Read: m_VixDiskLib_Read is fail - 14009, The server refused connection
12/16 20:06:02.025 1138 Facility ???ERROR: CPPConverting::ConvertImage: Read 3
12/16 20:06:17.995 1138 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [InternalRaid] Docuware2/Docuware2-000002.vmdk
12/16 20:06:17.995 1138 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=4
12/16 20:06:17.995 1138 Facility ???INFO: ESXVmdk::ParseFile: Close disk
12/16 20:06:17.995 1138 Facility ???INFO: ESXVmdk::ParseFile: Disconnect
12/16 20:06:21.547 1138 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 9C:3E:0B:F8:9C:26:ED:38:66:DD:84:B5:06:0E:48:78:FB:EB:AC:08
Sat Dec 17, 2022 8:56 am
Are firewall ports open? It looks like an accessibility issue.
dwindheim
Sat Dec 17, 2022 4:32 pm
They should be, we did a migration with Starwind V2V last week from the same ESXi host to the same Hyper-V host but I'll verify.
Sat Dec 17, 2022 5:29 pm
So, was it working before?
Please dig into the possible changes.
