GBDickinson
Mon Nov 28, 2022 2:53 am
I'm attempting to move a VM from ESXi to Azure. I've set up the application with "Owner" permissions to the Subscription, but both times I've attempted the conversion it ends like this:
11/27 20:38:33.579 10bc Facility ???INFO: VMConverter::AzureConverter::CreateVM: InProgress
11/27 20:38:33.677 10bc Facility ???INFO: VMConverter::AzureConverter::CreateVM: InProgress
11/27 20:38:33.771 10bc Facility ???INFO: VMConverter::AzureConverter::CreateVM: Succeeded
11/27 20:38:33.934 10bc Facility ???ERROR: VMConverter::AzureConverter::CreateVM: CreateDisk Status code: 400 Error code: BadRequest Message: Changing property 'sourceUri' is not allowed for existing disk '[Disk Name]'.
11/27 20:38:33.934 10bc Facility ???ERROR: CPPConverting::ConverterAzure: Create VM Error sending request to Azure.
11/27 20:38:33.938 10bc Facility ???INFO: WrapperESXI::connect: m_url - https://10.200.10.11/sdk
11/27 20:38:33.960 10bc Facility ???INFO: WrapperESXI::connect: fullName - [Name], key - [key]
11/27 20:38:33.960 10bc Facility ???ERROR: CPPConverting::Convert: FAILED
Searching the forum for "sourceuri" returns no results. Any ideas what I might be doing wrong?
GBDickinson on Tue Nov 29, 2022 6:48 pm, edited 1 time in total.
GBDickinson
Tue Nov 29, 2022 5:42 pm
Yes, the VM is powered off. I followed the linked instructions for the first attempt, and when that did not work, I changed the subscription access to "Owner" in case it was a security issue.
GBDickinson
Wed Nov 30, 2022 1:51 am
No snapshots, this is a fresh OVA deployment of a VMware Identity Management Appliance from OVA. For what it's worth, the disks are created and uploaded successfully, it just errors when creating an Azure VM based on the uploaded disks.
Wed Nov 30, 2022 11:45 am
If it fails to create VM in Azure even based on the disk which is already in Azure, there's something with the Azure account settings, I believe.
