Hyper-V to vCenter 7.0.3 conversion error
dphungofficial
Tue May 24, 2022 4:28 pm
I am converting a VHDX to VMDK, and the VM gets created in vCenter but when creating the image it failed due to "m_VixDiskLib_Open is fail - 4, A file was not found". Error is below. Any help would be appreciated.
5/24 12:17:55.308 309c Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
5/24 12:17:55.308 34dc Facility ???INFO: CPPConverting::Convert: InConvertType: 8, OutConvertType: 6
5/24 12:17:57.346 34dc Facility ???INFO: VMConverter::ESXIConverter::CreateVM: createVM is true, vm-90472
5/24 12:17:57.346 34dc Facility ???INFO: CPPConverting::ConverterESX: Create VM vm-90472
5/24 12:18:07.387 34dc Facility ???INFO: CPPConverting::ConvertImage: pathInput: C:\Affiliate VMs\Tucson\Virtual Hard Disks\CITRIN-SERVER-O.VHDX, pathOutput: [DS_vSAN_GeneralCompute] TucsonVM/CITRIN-SERVER-O.vmdk
5/24 12:18:07.387 34dc Facility ???INFO: CVHDXFile::getCurrentHeader: Read header 1.
5/24 12:18:07.387 34dc Facility ???INFO: CVHDXFile::getCurrentHeader: Read header 2.
5/24 12:18:07.387 34dc Facility ???INFO: CVHDXFile::getCurrentHeader: Check correct header 1.
5/24 12:18:07.387 34dc Facility ???INFO: CVHDXFile::getCurrentHeader: Check correct header 2.
5/24 12:18:07.387 34dc Facility ???INFO: CVHDXFile::ParseFile: Log is empty.
5/24 12:18:07.387 34dc Facility ???INFO: CVHDXFile::getRegion: Read region header 1.
5/24 12:18:07.402 34dc Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
5/24 12:18:07.465 34dc Facility ???INFO: ESXVmdk::ParseFile: sFilename - [DS_vSAN_GeneralCompute] TucsonVM/CITRIN-SERVER-O.vmdk
5/24 12:18:07.465 34dc Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=vm-90472
5/24 12:18:07.480 34dc Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 6D:43:11:68:EE:F1:6C:A2:0F:9A:72:38:CF:DE:72:44:53:4D:5F:44
5/24 12:18:07.749 34dc Facility ???ERROR: ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 4, A file was not found
5/24 12:18:07.749 34dc Facility ???ERROR: ESXIDisk::CreateOutputImage: ParseFile is fail
5/24 12:18:07.749 34dc Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 1
5/24 12:18:07.764 34dc Facility ???INFO: WrapperHyperV::connect: Host - \\localhost\root\virtualization\v2
5/24 12:18:07.764 34dc Facility ???INFO: WrapperHyperV::init_version: HyperV version: 10.0.17763
5/24 12:18:07.764 34dc Facility ???ERROR: CPPConverting::Convert: FAILED
Thank you!
Fri May 27, 2022 1:48 pm
Greetings,
Welcome to StarWind Forum. Are you pointing to the vCentre IP or ESXi?
dphungofficial
Fri May 27, 2022 7:05 pm
I tried the vCenter IP first then I tried a few ESXi hosts IP. Both giving me the same issue.
Thank you.
Mon May 30, 2022 6:50 am
Greetings,
Please try converting VHDX->VMDK and attach it to the fresh-created VM then. Let me know if you run into any trouble.
