Error during VM conversion Esx 5.5 to 7
Jeromer
Thu Nov 25, 2021 10:35 am
I'm trying to convert Vmware virtual machines from Esx 5.5 to esx 7. It's woks for old Vm version (2003 server, redhat 6.0) but each time I try to convert a 2019 server or windows 10, I got the same error: the server refused the connection...
Thank you for your help.
Here are my logs :
The log file name: 'logs\V2V_Log-20211125-095000.log' (PID 14012)
Delete log file 'logs\V2V_Log-20211119-083030.log'.
11/25 9:50:00.536 1c44 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
11/25 9:50:00.536 1c44 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.268
11/25 9:50:00.540 1c44 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
11/25 9:50:00.540 1c44 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
11/25 9:50:00.543 1c44 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 19042
11/25 9:50:00.545 1c44 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - e7e80000
11/25 9:50:00.546 1c44 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - e7e80000
11/25 9:50:03.862 1c44 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
11/25 9:50:16.339 1c44 Facility ???INFO: WrapperESXI::connect: m_url - https://10.21.4.92/sdk
11/25 9:50:16.406 1c44 Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - 573cea71-a64e-a756-8b96-e75fac076667
11/25 9:50:16.407 1c44 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
11/25 9:50:16.547 1c44 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 5.5.0
11/25 9:50:19.860 1c44 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
11/25 9:50:21.580 1c44 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnectionTo
11/25 9:50:33.645 1c44 Facility ???INFO: WrapperESXI::connect: m_url - https://10.21.1.106/sdk
11/25 9:50:33.675 1c44 Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - 5251064b-d58d-0647-3217-585894dab7de
11/25 9:50:33.675 1c44 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsESX
11/25 9:50:33.708 1c44 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 7.0.3
11/25 9:50:59.532 1c44 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
11/25 9:50:59.540 1c28 Facility ???INFO: CPPConverting::Convert: InConvertType: 6, OutConvertType: 6
11/25 9:51:00.136 1c28 Facility ???INFO: CheckFileESX::CheckFileExistance: GetBrowser fail - File [Data Disk] SLGDCRDPCRDI320 was not found
11/25 9:51:00.741 1c28 Facility ???INFO: VMConverter::ESXIConverter::CreateVM: createVM is true, 3
11/25 9:51:00.742 1c28 Facility ???INFO: CPPConverting::ConverterESX: Create VM 3
11/25 9:51:00.797 1c28 Facility ???INFO: CPPConverting::ConvertImage: pathInput: [SVC-RDI3] PC-RDI-320/PC-RDI-320.vmdk, pathOutput: [Data Disk] SLGDCRDPCRDI320/PC-RDI-320.vmdk
11/25 9:51:01.418 1c28 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [SVC-RDI3] PC-RDI-320/PC-RDI-320.vmdk
11/25 9:51:01.418 1c28 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=68
11/25 9:51:01.433 1c28 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 23:F2:3D:47:D4:ED:CD:52:35:A0:0D:77:EA:FE:B9:BE:CB:B8:7D:7C
11/25 9:51:03.574 1c28 Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
11/25 9:51:04.895 1c28 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [Data Disk] SLGDCRDPCRDI320/PC-RDI-320.vmdk
11/25 9:51:04.895 1c28 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=3
11/25 9:51:04.904 1c28 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 6B:54:D1:BA:13:41:9B:70:16:88:9F:36:9D:7F:A3:85:DA:E1:C2:65
11/25 9:51:06.428 1c28 Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 0
11/25 10:08:37.163 1c28 Facility ???ERROR: VMwareFile::Read: m_VixDiskLib_Read is fail - 14009, The server refused connection
11/25 10:08:37.163 1c28 Facility ???ERROR: CPPConverting::ConvertImage: Read 3
Thu Nov 25, 2021 11:34 am
Could you try converting individual disks not VMs? Also, make sure to have the VM turned off.
Jeromer
Fri Nov 26, 2021 11:17 am
Hi ,
I've tried with the vmdk file only and the same result. (the server refused connection, always at 12%)
I've tried to transfer to two different Esx servers but it fails.
Fri Nov 26, 2021 4:14 pm
Can you copy the VMDK to Windows Server and convert it as a local file?
Make sure to turn off the VM in question to avoid possible data inconsistency.
Jeromer
Mon Nov 29, 2021 10:55 am
It's not an an issue with vmware 7 because when I try to copy the vmdk file from the Esx 5.5 to my local drive, I got the same error at 12% "the server refused connection"
Tue Nov 30, 2021 4:24 am
Can you copy the file locally and convert it, please?
