Error converting Windows 10 Machine
nestersan
Wed Sep 01, 2021 4:50 pm
The process goes through taking snapshots, creating image file, starts the conversion and generates an "Error Read file!" message.
I'm unsure where to go next in the process.
The log file name: 'logs\V2V_Log-20210901-120516.log' (PID 21940)
9/1 12:05:16.338 55b0 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
9/1 12:05:16.338 55b0 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.243
9/1 12:05:16.354 55b0 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
9/1 12:05:16.354 55b0 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
9/1 12:05:16.369 55b0 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 19043
9/1 12:05:16.385 55b0 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\WINDOWS\system32\wbem\wmiutils.dll - c5270000
9/1 12:05:41.529 55b0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eTypeP2V
9/1 12:05:47.154 55b0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHDDSelect
9/1 12:05:47.185 55b0 Facility ???WARNING: PhysicalInfo::PhysicalDisksInfo::InitDisks: GetDiskFreeSpace \\?\Volume{19c7e34a-0000-0000-0000-50183a000000}\ fail - 87. The parameter is incorrect.
9/1 12:05:59.688 55b0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
9/1 12:06:01.391 55b0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eFormat
9/1 12:06:08.876 55b0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOptionsHyperV
9/1 12:06:16.641 55b0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOutputFile
9/1 12:06:30.816 55b0 Facility ???INFO: CPPOutputFile::onNext: Out path: H:\VM.vhdx, Out format 10
9/1 12:06:30.832 55b0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
9/1 12:06:30.847 54ac Facility ???INFO: CPPConverting::Convert: InConvertType: 2, OutConvertType: 4
9/1 12:06:30.847 54ac Facility ???INFO: CPPConverting::ConvertImage: pathInput: 0, pathOutput: H:\VM.vhdx
9/1 12:06:30.847 54ac Facility ???INFO: P2V::CreateInputImage: path 0
9/1 12:06:30.847 54ac Facility ???INFO: P2V::CreateInputImage: Size 0 - 250059350016, BytesPerSector - 512
9/1 12:17:29.387 54ac Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
9/1 12:17:29.403 54ac Facility ???INFO: MicrosoftFile::NewFile: sFilename - H:\VM.vhdx, nMaxSize - 488397168, fileType - 1
9/1 12:17:29.591 54ac Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 0
9/1 12:17:29.591 54ac Facility ???ERROR: CPPConverting::ConvertImage: Read 3
9/1 12:25:08.874 54ac Facility ???ERROR: CPPConverting::Convert: FAILED
9/1 12:27:11.367 55b0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocation
9/1 12:27:13.773 55b0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eTypeP2V
9/1 12:27:16.067 55b0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHDDSelect
9/1 12:27:20.601 55b0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
9/1 12:27:22.695 55b0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eFormat
9/1 12:27:24.273 55b0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOptionsHyperV
9/1 12:27:26.570 55b0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOutputFile
9/1 12:27:46.569 55b0 Facility ???INFO: CPPOutputFile::onNext: Out path: H:\VM.vhdx, Out format 10
9/1 12:27:46.569 55b0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
9/1 12:27:46.569 57c0 Facility ???INFO: CPPConverting::Convert: InConvertType: 2, OutConvertType: 4
9/1 12:27:46.569 57c0 Facility ???INFO: CPPConverting::ConvertImage: pathInput: 0, pathOutput: H:\VM.vhdx
9/1 12:27:46.569 57c0 Facility ???INFO: P2V::CreateInputImage: path 0
9/1 12:27:46.569 57c0 Facility ???INFO: P2V::CreateInputImage: Size 0 - 250059350016, BytesPerSector - 512
9/1 12:28:41.918 57c0 Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
9/1 12:28:41.918 57c0 Facility ???INFO: MicrosoftFile::NewFile: sFilename - H:\VM.vhdx, nMaxSize - 488397168, fileType - 1
9/1 12:28:42.059 57c0 Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 0
9/1 12:28:42.059 57c0 Facility ???ERROR: CPPConverting::ConvertImage: Read 3
Thu Sep 02, 2021 5:48 am
Are you converting a local file or file on a share?
