V2V ESXI 6.7 VM to Hyper-v 2019
Jester
Mon Aug 23, 2021 10:18 am
Hi!
I'm trying to convert vms from an ESXI 6.7 to a free hyper-v 2019.
I can select what i want to convert, to where, but it fails.
Thx in advance for the help!
The log file name: 'logs\V2V_Log-20210823-120505.log' (PID 4888)
8/23 12:05:05.786 1484 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
8/23 12:05:05.786 1484 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.243
8/23 12:05:05.786 1484 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
8/23 12:05:05.786 1484 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
8/23 12:05:05.786 1484 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 17763
8/23 12:05:05.786 1484 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 52aa0000
8/23 12:05:05.801 1484 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 52aa0000
8/23 12:05:10.645 1484 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
8/23 12:05:26.355 1484 Facility ???INFO: WrapperESXI::connect: m_url - https://192.168.3.8/sdk
8/23 12:05:26.386 1484 Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - 52a57ac7-1dd0-ad89-4892-3f3b057dc9a4
8/23 12:05:26.386 1484 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
8/23 12:05:26.480 1484 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 6.7.0
8/23 12:05:31.596 1484 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
8/23 12:05:35.940 1484 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnectionTo
8/23 12:05:54.136 1484 Facility ???INFO: WrapperHyperV::connect: Host - \\192.168.3.247\root\virtualization\v2
8/23 12:05:54.324 1484 Facility ???INFO: WrapperHyperV::connect: user: lib\mcs
8/23 12:05:54.370 1484 Facility ???INFO: WrapperHyperV::connectToCIMV2: user: lib\mcs
8/23 12:05:54.464 1484 Facility ???INFO: WrapperHyperV::init_version: HyperV version: 10.0.17763
8/23 12:05:54.464 1484 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsHyperV
8/23 12:05:56.389 1484 Facility ???INFO: WrapperHyperV::connectToCIMV2: user: lib\mcs
8/23 12:06:23.113 1484 Facility ???ERROR: HyperVSelectFolderDlg::OnInit: WNetAddConnection2 \\192.168.3.247 fail - 53
8/23 12:06:23.113 1484 Facility ???ERROR: HyperVSelectFolderDlg::FillItemExpanded: FindFirstFile - 53
8/23 12:06:45.732 1484 Facility ???ERROR: HyperVSelectFolderDlg::FillItemExpanded: FindFirstFile - 53
8/23 12:06:50.374 1484 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
8/23 12:06:50.389 11bc Facility ???INFO: CPPConverting::Convert: InConvertType: 6, OutConvertType: 8
8/23 12:06:50.718 11bc Facility ???INFO: WrapperHyperV::modify_cpu_and_memory: MaxCPU - 32
8/23 12:06:50.749 11bc Facility ???INFO: WrapperHyperV::getMaxMemory: MaxRAM - 126308
8/23 12:06:50.843 11bc Facility ???INFO: CPPConverting::ConverterHyperV: Create VM 1E6D602B-3832-4683-A286-D4D53DCB1224
8/23 12:06:50.858 11bc Facility ???INFO: CPPConverting::ConvertImage: pathInput: [datastore1] puttyvm/puttyvm.vmdk, pathOutput: E:\puttyvm\Virtual Hard Disks\puttyvm.vhdx
8/23 12:06:50.905 11bc Facility ???INFO: ESXVmdk::ParseFile: sFilename - [datastore1] puttyvm/puttyvm.vmdk
8/23 12:06:50.905 11bc Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=15
8/23 12:06:50.921 11bc Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - F9:4A:51:E9:7D:C6:E2:B5:13:69:1A:3D:C8:AB:21:75:52:83:DF:8D
8/23 12:06:51.811 11bc Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
8/23 12:06:52.561 11bc Facility ???WARNING: HyperVDisk::connect: WNetAddConnection2 \\192.168.3.247 fail - 53
8/23 12:06:52.561 11bc Facility ???WARNING: HyperVDisk::CreateOutputImage: Error create directory 53 - \\192.168.3.247\E$\puttyvm\Virtual Hard Disks. The network path was not found.
8/23 12:06:52.561 11bc Facility ???INFO: MicrosoftFile::NewFile: sFilename - \\192.168.3.247\E$\puttyvm\Virtual Hard Disks\puttyvm.vhdx, nMaxSize - 524288000, fileType - 2
8/23 12:06:52.561 11bc Facility ???ERROR: MicrosoftFile::NewFile: CreateVirtualDisk is fail - 53. The network path was not found.
8/23 12:06:52.561 11bc Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 1
8/23 12:06:52.561 11bc Facility ???INFO: WrapperESXI::connect: m_url - https://192.168.3.8/sdk
8/23 12:06:52.593 11bc Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - 52b3b096-0134-9bda-b68d-868d2a6afbb0
8/23 12:06:52.593 11bc Facility ???ERROR: CPPConverting::Convert: FAILED
Mon Aug 23, 2021 12:21 pm
Are you converting to local drive or to share? I can see the connectivity problem there.
Jester
Mon Aug 23, 2021 12:45 pm
I'm converting to a remote free hyper-v 2019 server.
Guess then it's a share.
BTW i'm connecting as a domain admin.
Jester
Tue Aug 24, 2021 10:27 am
Ok, so after enabling Network Discovery and File and Printer Sharing on the hyper-v host, now it's working.
Thx
Tue Aug 24, 2021 1:31 pm
Glad to know that everything works great. Cheers.
ElChucho
Mon Aug 26, 2024 10:59 pm
I'm running into the same thing on the Free Hyper-V 2019. How did you enable Network and file sharing?
NVM, figured it out.
netsh advfirewall firewall set rule group=”Network Discovery” new enable=Yes
netsh advfirewall firewall set rule group="File and Printer Sharing" new enable=Yes
In case anyone else needs it.
Thu Sep 12, 2024 6:15 pm
Thank you for reporting it back! We appreciate.
