Disk space when doing conversion to Hyper-V cluster
Buggy
Mon Jul 05, 2021 2:44 pm
The free V2V Converter works really great. Thanks for making it available!
Maybe this is already mentioned before, but I did not see it:
I am in the process of going from ESXi to Hyper-V. The Hyper-V servers are in a Windows Failover Cluster with a SAN. The SAN storage space is on the Hyper-V server available as C:'\ClusterStorage\Volume1, etc. So this path is used by the Converter. Which is fine.
But the Converter checks disk space, but it returns the disk space on the C: drive of the Hyper-V host and not the SAN disk space. So, with a C: drive space of 100 GB and a SAN disk space of 3 TB, the conversion of a image of 120 GB to the Hyper-V cluster is not allowed. Would it be possible to change this behavior?
Jac
Tue Jul 06, 2021 3:29 am
Welcome to StarWind Forum. Please let me double-check that.
Mon Jul 19, 2021 5:15 am
Problem confirmed. We are working on fixing this problem. Will keep you posted.
Buggy
Mon Jul 19, 2021 7:29 am
Thank you, Yaroslav!
Jac
Sat Aug 07, 2021 7:39 am
Sorry for such a delay, the fix is going to be present in the builds to come.
Thank you for your effort!
Buggy
Sat Aug 07, 2021 8:22 am
Thank you again, Yaroslav, also for posting the update!
I will try when a build is available.
With kind regards,
Jac
Sat Aug 07, 2021 10:09 am
Thank you for your effort. Please check the release notes ocasionally.
Cheers,
