Conversion Issue
DG_Byron
Mon Jun 14, 2021 6:33 pm
Have used this tool many time with no issues, but getting the below error below. Any ideas?
Converting a VM to Azure.
Request has neither imageReference nor osDisk. In order to create a managed disk VM, at least imageReference needs to be provided, whereas for a blob based disk VM, osDisk is required.
6/14 11:22:18.455 211c Facility ???ERROR: CPPConverting::Convert: FAILED
The log file name: 'logs\V2V_Log-20210614-102524.log' (PID 4464)
6/14 10:25:24.705 a94 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
6/14 10:25:24.706 a94 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.243
6/14 10:25:24.708 a94 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
6/14 10:25:24.708 a94 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
6/14 10:25:24.710 a94 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 17763
6/14 10:25:24.719 a94 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 6cce0000
6/14 10:25:24.720 a94 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 6cce0000
6/14 10:25:28.260 a94 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eTypeP2V
6/14 10:25:30.667 a94 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVolumeSelectVM
6/14 10:25:32.202 a94 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
6/14 10:25:34.440 a94 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eAzureConnectionTo
6/14 10:26:23.861 a94 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsAzure
6/14 10:28:11.739 a94 Facility ???INFO: CPPVMSettingsAzure::onNext: Create new NI
6/14 10:28:11.739 a94 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
6/14 10:28:11.743 211c Facility ???INFO: CPPConverting::Convert: InConvertType: 3, OutConvertType: 10
6/14 10:28:30.722 211c Facility ???INFO: CPPConverting::ConvertImage: pathInput: 0, pathOutput: https://storage3506.blob.core.windows.net/dga-azu-app001/HDD0.vhd
6/14 10:28:30.722 211c Facility ???INFO: P2V::CreateInputImage: path 0
6/14 10:28:30.722 211c Facility ???INFO: P2V::CreateInputImage: Size 0 - 107374182400, BytesPerSector - 512
6/14 10:28:33.944 211c Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
6/14 10:28:37.756 211c Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 0
6/14 10:28:37.761 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 17584, dwCountBytes - 17584
6/14 10:29:08.095 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:34:17.299 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:40:58.449 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:42:32.538 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:42:59.346 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:43:21.456 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:44:00.366 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:45:37.332 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:46:35.221 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:46:58.271 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:47:52.559 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:49:07.591 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:50:39.271 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:52:05.592 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:53:01.578 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:53:25.745 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:53:57.552 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:54:21.534 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:56:05.985 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:56:32.582 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:56:55.010 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:58:29.885 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 10:59:30.725 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 11:00:35.395 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 11:02:19.009 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 11:03:30.924 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 11:07:42.721 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 11:09:43.800 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 11:12:35.639 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 11:14:09.622 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 11:16:11.676 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 11:16:48.658 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 11:17:10.580 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 11:17:32.590 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 11:19:22.925 211c Facility ???INFO: P2V::getSectorsNext: countClusters - 3259184, dwCountBytes - 3259184
6/14 11:22:07.571 211c Facility ???INFO: CPPConverting::ConvertImage: Success
6/14 11:22:16.470 211c Facility ???INFO: VMConverter::AzureConverter::CreateVM: InProgress
6/14 11:22:16.564 211c Facility ???INFO: VMConverter::AzureConverter::CreateVM: InProgress
6/14 11:22:16.658 211c Facility ???INFO: VMConverter::AzureConverter::CreateVM: InProgress
6/14 11:22:16.736 211c Facility ???INFO: VMConverter::AzureConverter::CreateVM: InProgress
6/14 11:22:16.830 211c Facility ???INFO: VMConverter::AzureConverter::CreateVM: InProgress
6/14 11:22:16.908 211c Facility ???INFO: VMConverter::AzureConverter::CreateVM: InProgress
6/14 11:22:17.002 211c Facility ???INFO: VMConverter::AzureConverter::CreateVM: InProgress
6/14 11:22:17.095 211c Facility ???INFO: VMConverter::AzureConverter::CreateVM: InProgress
6/14 11:22:17.283 211c Facility ???INFO: VMConverter::AzureConverter::CreateVM: InProgress
6/14 11:22:17.455 211c Facility ???INFO: VMConverter::AzureConverter::CreateVM: Succeeded
6/14 11:22:18.455 211c Facility ???ERROR: VMConverter::AzureConverter::CreateVM: CreateVirtualMachine Status code: 409 Error code: OperationNotAllowed Message: Request has neither imageReference nor osDisk. In order to create a managed disk VM, at least imageReference needs to be provided, whereas for a blob based disk VM, osDisk is required.
6/14 11:22:18.455 211c Facility ???ERROR: CPPConverting::ConverterAzure: Create VM Error sending request to Azure.
Mon Jun 14, 2021 7:06 pm
Welcome to StarWind Forum. Please try converting the disk alone.
DG_Byron
Mon Jun 14, 2021 7:37 pm
Not sure what you mean. When I go to convert, this VM list two disks. C: and the system reserved.
Tue Jun 15, 2021 3:59 am
You were converting the VM here.
Now, please try converting its disk and the system reserved partition.
