Access is Denied. (0x80070005)
monts
Fri May 28, 2021 4:15 pm
I am attempting remote VMWare to HyperV.
I am able to authenticate to VMWare but when I attempt to enter HyperV connection paramaters it gives me "Access is Denied. (0x80070005).
I have tried using FQDN, IP, etc.
I searched forum and the only other mention seemed a different issue.
See below for log
The log file name: 'logs\V2V_Log-20210527-170238.log' (PID 4760)
5/27 17:02:38.354 12d8 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
5/27 17:02:38.354 12d8 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.243
5/27 17:02:38.354 12d8 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
5/27 17:02:38.354 12d8 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
5/27 17:02:38.354 12d8 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 17763
5/27 17:02:38.401 12d8 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 29170000
5/27 17:02:51.166 12d8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
5/27 17:03:50.266 12d8 Facility ???INFO: WrapperESXI::connect: m_url - https://192.168.2.3/sdk
5/27 17:03:50.360 12d8 Facility ???INFO: WrapperESXI::connect: fullName - Administrator
5/27 17:03:50.360 12d8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
5/27 17:03:50.500 12d8 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 6.0.0
5/27 17:04:06.561 12d8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
5/27 17:04:12.810 12d8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnectionTo
5/27 17:04:34.298 12d8 Facility ???INFO: WrapperHyperV::connect: Host - \\mtlsrk-hv1001p\root\virtualization\v2
5/27 17:04:35.505 12d8 Facility ???ERROR: WrapperHyperV::connect: pLoc->ConnectServer \\mtlsrk-hv1001p\root\virtualization\v2 - 0x80070005
5/27 17:04:35.505 12d8 Facility ???ERROR: WrapperHyperV::failResultToStr: Last Error - Access is denied.
(0x80070005)
5/27 17:04:35.505 12d8 Facility ???ERROR: VMConverter::HyperVConverter::Connection: connect fail - 0x80070005
5/27 17:04:37.692 12d8 Facility ???WARNING: CPPHYPERVConnectionTo::onNext: connect Access is denied.
(0x80070005)
Mon May 31, 2021 3:38 am
Welcome to StarWind Forum.
Is it P2V or V2V conversion?
monts
Tue Jun 01, 2021 4:09 pm
V2V - VMWare to HyperV
The VMWare accepts the information per the prior listed logs, but something happens on the HyperV side.
Wed Jun 02, 2021 1:48 pm
Are you logging using the local admin or the domain administrator?
monts
Tue Jun 08, 2021 3:38 pm
Sorry for the slow reply, got distracted by a critical software issue.
I am logged onto my conversion computer using the local administrator. Do I need to be logging into the server running the software as a domain admin?
Wed Jun 09, 2021 8:11 am
You need to be logged as a local admin. Are you able to proceed further than the credentials screen? If so, can I have the full conversion logs once again please?
stephen645
Fri Jun 11, 2021 6:37 am
yaroslav (staff) wrote:You need to be logged as a local admin. Are you ableslope gameto proceed further than the credentials screen? If so, can I have the full conversion logs once again please?
I can't log in either!!!
Fri Jun 11, 2021 7:04 am
There must be something with logging in. Did you try conversion for another machine?
noahcentineo
Mon Aug 23, 2021 3:18 am
I'm logged in as the local administrator on my converting PC. Is it necessary for me to log in as a domain admin to the server where the program is installed?
Mon Aug 23, 2021 5:32 am
While converting the file, please log in as root on the VMware server and as a local admin on the destination server.
alicelove21
Thu Jul 14, 2022 2:24 am
Have you tried converting for another machine?
Tue Feb 27, 2024 3:17 pm
It won't help. You need to have full "root" (or "Administrator") privileges to access virtual machines.
alicelove21 wrote: ↑
