esxi5.1 to esxi6.7
clickin
Fri Apr 02, 2021 2:36 pm
I am trying to move a vm from esxi5.1 to esxi6.7. I downloaded the StarWind v2v converter, but it says it only works with esxi5.5 or later. I was able to log into esx5.1 and put in the destination for the esxi6.7 but I didn't do the convert to move it.
What are the issues with esxi5.1 and is there a work around? I didn't want to do this until I talked to someone about it. Just call me chicken. LOL :D
Fri Apr 02, 2021 2:39 pm
Welcome to StarWind forum!
I guess there is something with libraries V2V uses: they may not work with old ESXi versions.
clickin
Fri Apr 02, 2021 2:45 pm
Is it not going to work or should I try something else? Do you have an old version of the converter that would work?
Fri Apr 02, 2021 3:04 pm
Can I see the conversion logs, please? Those are in C:\Program Files\StarWind\StarWind V2V Converter.
clickin
Fri Apr 02, 2021 3:05 pm
I didn't run it yet because I was afraid. Do you still want conversion logs?
clickin
Fri Apr 02, 2021 3:09 pm
The log file name: 'logs\V2V_Log-20210402-090040.log' (PID 18436)
4/2 9:00:40.459 47e8 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
4/2 9:00:40.459 47e8 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.243
4/2 9:00:40.465 47e8 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
4/2 9:00:40.466 47e8 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
4/2 9:00:40.470 47e8 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 19041
4/2 9:00:40.475 47e8 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\WINDOWS\system32\wbem\wmiutils.dll - 76e80000
4/2 9:00:40.476 47e8 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\WINDOWS\system32\wbem\wmiutils.dll - 76e80000
clickin
Fri Apr 02, 2021 3:10 pm
The log file name: 'logs\V2V_Log-20210402-085838.log' (PID 9096)
4/2 8:58:38.860 4ab8 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
4/2 8:58:38.860 4ab8 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.243
4/2 8:58:38.867 4ab8 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
4/2 8:58:38.868 4ab8 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
4/2 8:58:38.921 4ab8 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 19041
4/2 8:58:38.998 4ab8 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\WINDOWS\system32\wbem\wmiutils.dll - 76e80000
4/2 8:58:39.000 4ab8 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\WINDOWS\system32\wbem\wmiutils.dll - 76e80000
4/2 8:58:54.967 4ab8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
4/2 8:59:07.312 4ab8 Facility ???INFO: WrapperESXI::connect: m_url - https://10.10.20.5/sdk
4/2 8:59:07.485 4ab8 Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - 567852a9-b9dc-5651-16a9-30531e846238
4/2 8:59:07.486 4ab8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
4/2 8:59:07.783 4ab8 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 5.1.0
4/2 8:59:17.886 4ab8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
4/2 8:59:20.870 4ab8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnectionTo
4/2 8:59:38.335 4ab8 Facility ???INFO: WrapperESXI::connect: m_url - https://10.10.20.31/sdk
4/2 8:59:38.407 4ab8 Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - 5262f790-01cf-2ba8-f413-697506e3e2ee
4/2 8:59:38.407 4ab8 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsESX
4/2 8:59:38.456 4ab8 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 6.7.0
Fri Apr 02, 2021 3:23 pm
Hello. Please run the conversion. If it fails, please share the logs with us. The logs do not contain the error messages now.
Please note that StarWind V2V Converter supports conversion starting from ESXi 5.5.
clickin
Fri Apr 02, 2021 4:02 pm
here is the conversion log
he log file name: 'logs\V2V_Log-20210402-110328.log' (PID 8876)
4/2 11:03:28.511 4958 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
4/2 11:03:28.511 4958 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.243
4/2 11:03:28.513 4958 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
4/2 11:03:28.513 4958 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
4/2 11:03:28.521 4958 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 19041
4/2 11:03:28.563 4958 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\WINDOWS\system32\wbem\wmiutils.dll - 3e910000
4/2 11:03:35.424 4958 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnection
4/2 11:03:47.720 4958 Facility ???INFO: WrapperESXI::connect: m_url - https://10.10.20.5/sdk
4/2 11:03:47.963 4958 Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - 88799b50-e976-a6ae-fe6b-c857136d043e
4/2 11:03:47.963 4958 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
4/2 11:03:48.226 4958 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 5.1.0
4/2 11:03:59.215 4958 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
4/2 11:04:00.533 4958 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnectionTo
4/2 11:04:12.790 4958 Facility ???INFO: WrapperESXI::connect: m_url - https://10.10.20.31/sdk
4/2 11:04:12.859 4958 Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - 52419860-77f6-cb70-ec55-d12845a5278a
4/2 11:04:12.859 4958 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsESX
4/2 11:04:12.913 4958 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 6.7.0
4/2 11:04:25.053 4958 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
4/2 11:04:25.068 4484 Facility ???INFO: CPPConverting::Convert: InConvertType: 6, OutConvertType: 6
4/2 11:04:25.200 4484 Facility ???INFO: CheckFileESX::CheckFileExistance: GetBrowser fail - File [DELLDataStore] Citrix Gateway was not found
4/2 11:04:25.686 4484 Facility ???INFO: VMConverter::ESXIConverter::CreateVM: createVM is true, 1
4/2 11:04:25.686 4484 Facility ???INFO: CPPConverting::ConverterESX: Create VM 1
4/2 11:04:25.739 4484 Facility ???INFO: CPPConverting::ConvertImage: pathInput: [local_HD] Citrix Gateway/Citrix Gateway.vmdk, pathOutput: [DELLDataStore] Citrix Gateway/Citrix Gateway.vmdk
4/2 11:04:26.472 4484 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [local_HD] Citrix Gateway/Citrix Gateway.vmdk
4/2 11:04:26.472 4484 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=5
4/2 11:04:26.488 4484 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - AC:2D:EF:52:A4:C7:E4:91:DE:8C:A5:06:A5:C8:2A:11:8A:CD:AE:1A
4/2 11:04:27.291 4484 Facility ???ERROR: ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 14009, The server refused connection
4/2 11:04:27.291 4484 Facility ???ERROR: ESXIDisk::CreateInputImage: ParseFile is fail
4/2 11:04:27.291 4484 Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 1
4/2 11:04:27.291 4484 Facility ???INFO: WrapperESXI::connect: m_url - https://10.10.20.5/sdk
4/2 11:04:27.379 4484 Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - b44cd222-ca46-ad0e-dba2-74ffc4b40fcb
4/2 11:04:27.379 4484 Facility ???ERROR: CPPConverting::Convert: FAILED
Tue Apr 06, 2021 8:08 am
Thank you for sharing the logs. V2V Converter cannot connect to ESXi 5.1 for some reason. Please try updating it to 5.5.
