Converter can't list datastore folders.
Leinth
Mon Jan 11, 2021 4:17 pm
Recently I have encountered and error with esxi and Converter tool.
I'm getting the following error messages when trying to upload vmdk files to and esxi host.
1/11 18:05:14.858 648 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 6.7.0
1/11 18:05:19.969 648 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOptionsESXI
1/11 18:05:21.688 648 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eSelectFolder
1/11 18:05:21.688 648 Facility ???ERROR: CountOverheadSize: Invalid type - 13
1/11 18:05:23.704 648 Facility ???WARNING: ESXiSelectFolderDlg::FillItemExpanded: HttpQueryInfo /folder?dcPath=ha-datacenter&dsName=vsan-NVMe - 12150. Unknown error
1/11 18:05:23.735 648 Facility ???WARNING: ESXiSelectFolderDlg::FillItemExpanded: HttpQueryInfo /folder?dcPath=ha%2ddatacenter&dsName=vsan-NVMe - 12150. Unknown error
1/11 18:05:23.750 648 Facility ???WARNING: ESXiSelectFolderDlg::FillItemExpanded: HttpQueryInfo /folder?dcPath=ha%252ddatacenter&dsName=vsan-NVMe - 12150. Unknown error
1/11 18:05:23.750 648 Facility ???WARNING: ESXiSelectFolderDlg::FillItemExpanded: strTemp is empty
Mon Jan 11, 2021 6:28 pm
Welcome to StarWind forum.
Can I have the entire log, please? I assume that conversion is done via GUI. If that's the case, can I have the error encounter in GUI?
Leinth
Mon Jan 11, 2021 6:35 pm
Yes it's in the UI. there is no error message, just an empty screen where you chose the output file location.
The log file name: 'logs\V2V_Log-20210111-183131.log' (PID 8384)
1/11 18:31:31.972 3834 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
1/11 18:31:31.972 3834 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.0.202
1/11 18:31:31.972 3834 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
1/11 18:31:31.972 3834 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_RUSSIAN
1/11 18:31:31.972 3834 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
1/11 18:31:31.972 3834 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 17763
1/11 18:31:31.972 3834 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - c5790000
1/11 18:31:35.989 3834 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputFile
1/11 18:31:39.277 3834 Facility ???INFO: CPPInputFile::checkFile: Select file: D:\Restore\INKvDC01-1.vhdx
1/11 18:31:39.277 3834 Facility ???INFO: MicrosoftFile::ParseFile: sFilename - D:\Restore\INKvDC01-1.vhdx
1/11 18:31:39.355 3834 Facility ???INFO: CPPInputFile::checkFile: ParseFile: 0
1/11 18:31:39.355 3834 Facility ???INFO: CPPInputFile::checkFile: File type: IDS_IMAGE_CONVERTER_FORMAT_NAME_VHDX  File size: 209715200 sectors
1/11 18:31:40.516 3834 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
1/11 18:31:43.063 3834 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnectionTo
1/11 18:31:58.731 3834 Facility ???INFO: WrapperESXI::connect: m_url - https://10.81.16.51/sdk
1/11 18:31:58.762 3834 Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - 521b56dd-3f24-aa0b-7664-ccb42eb49378
1/11 18:31:58.762 3834 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOutputVM
1/11 18:31:58.903 3834 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 6.7.0
1/11 18:32:04.531 3834 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOptionsESXI
1/11 18:32:06.328 3834 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eSelectFolder
1/11 18:32:06.328 3834 Facility ???ERROR: CountOverheadSize: Invalid type - 13
1/11 18:32:08.032 3834 Facility ???WARNING: ESXiSelectFolderDlg::FillItemExpanded: HttpQueryInfo /folder?dcPath=ha-datacenter&dsName=vsan-NVMe - 12150. Unknown error
1/11 18:32:08.047 3834 Facility ???WARNING: ESXiSelectFolderDlg::FillItemExpanded: HttpQueryInfo /folder?dcPath=ha%2ddatacenter&dsName=vsan-NVMe - 12150. Unknown error
1/11 18:32:08.063 3834 Facility ???WARNING: ESXiSelectFolderDlg::FillItemExpanded: HttpQueryInfo /folder?dcPath=ha%252ddatacenter&dsName=vsan-NVMe - 12150. Unknown error
1/11 18:32:08.079 3834 Facility ???WARNING: ESXiSelectFolderDlg::FillItemExpanded: strTemp is empty
Tue Jan 12, 2021 4:15 am
Just to be sure that I get it right. Can you connect to the ESXi host over SSH from the VM/computer where the Converter is running?
Leinth
Tue Jan 12, 2021 7:30 am
Yes, I can upload images from porwercli fine.
This is where I basically stopped https://ibb.co/rdVqzQG .
Tue Jan 12, 2021 12:35 pm
Just PMd you the link at the latest build. Should be working fine there.
Leinth
Tue Jan 12, 2021 3:09 pm
Thank you. It's working now.
Tue Jan 12, 2021 4:46 pm
You are always welcome. Glad to read that everything is alright.
