Operation Timed out - converting from vhdx to vmdk
rebnetech
Sun Apr 14, 2019 1:09 pm
I was converting a local vhdx file to a vmdk file. This was being done from a local drive to the VMWare eSXi 6.0 datastore. It's a 2.7TB file. It seemed to have converted the file however at the end it stated the following error.
290 Facility ???ERROR: CESXConnector::Write: InternetWriteFile is fail - 12002
4/14 2:25:28.367 290 Facility ???ERROR: CESXConnector::Write: InternetGetLastResponseInfoA - 0,
4/14 2:25:28.460 290 Facility ???INFO: CESXConnector::SetError: Internet Error Code - 12002
4/14 2:25:28.492 290 Facility ???INFO: CESXConnector::SetError: Error info - The operation timed out
4/14 2:25:28.492 290 Facility ???ERROR: CPPConverting::ConvertImage: Write 122
Seemed to have timed out with 500GB left according to the comparison of the two files.
Can you provide an idea of what happened? It's pretty crucial at this point to get this file. The server that is hosting the Hyper-V VM is dying and we want to get the VMWare conversion completed so we can prevent the disaster.
Oleg(staff)
Mon Apr 15, 2019 2:39 pm
Could you please provide the full log from StarWind V2V Converter?
rebnetech
Wed Apr 17, 2019 3:16 pm
Unfortunately, the VM I was using for this effort died on me and I deleted the vmdk by mistake. So I lost the full log. I will be trying this again shortly.
Wed Apr 17, 2019 4:14 pm
OK. If you run into a similar issue, be sure to get the logs saved.
