sradhube
Sun Feb 10, 2019 6:09 pm
i try to migrate from hyper-V to vmware, running starwind v2v converter directly on Hyper-V Host, i am able to login and connect to hyper-v and can see the registered vms. After expanding them the only error message i see is "VM is fail!".
I can reproduce the same error on three different Hyper-V Hosts, running the converter with a local admin account
Does anyone know this error and hopefully a solution for that?
P.s.: Version 9 Build 110
regards
stefan
stefcho034
Thu May 16, 2019 2:50 pm
Hello!
I have the same situation, the logs say:
5/16 17:17:31.821 6dc Facility ???ERROR: WrapperHyperV::get_generation_type: FROM Msvm_VirtualSystemSettingData Get VirtualSystemSubType - 0x80041002
5/16 17:17:31.821 6dc Facility ???ERROR: VMConverter::HyperVConverter::GetVMInfo: get_generation_type fail - 0x80041002
5/16 17:17:31.821 6dc Facility ???ERROR: ICPPTree::getVMInfo: GetVMInfo fail - Not found
5/16 17:17:41.429 6dc Facility ???ERROR: WrapperHyperV::get_generation_type: FROM Msvm_VirtualSystemSettingData Get VirtualSystemSubType - 0x80041002
5/16 17:17:41.429 6dc Facility ???ERROR: VMConverter::HyperVConverter::GetVMInfo: get_generation_type fail - 0x80041002
5/16 17:17:41.429 6dc Facility ???ERROR: ICPPTree::getVMInfo: GetVMInfo fail - Not found
The environment is Hyper-V Failover Cluster - 2012
Thanks a lot!
Oleg(staff)
Mon May 20, 2019 4:19 pm
Hello stefcho034,
Thank you for your input.
This issue should be fixed with the next build of StarWind V2V Converter.
