StarWind iSCSI SAN
P2V This format is not supported Converted error
Postby IT-Paperfree » Fri Jan 25, 2019 5:02 pm
Just downloaded the new V2V converter.
Trying to P2V W2008R2 an receive this message after a few minutes:
This format is not supported (19) [122] Current virtual disk not supported. Converted error.
Any clues?
Regards
IT-Paperfree
Re: P2V This format is not supported Converted error
Postby Boris (staff) » Sun Jan 27, 2019 2:14 pm
Do you run the converter on the physical host that needs conversion to a VM?
Postby v2vfans » Thu Jan 31, 2019 8:11 am
the converter worked beautifully on win2016 --> ie converting win2016 physical host to vhdx
However, the converter gave the above reported [122] error on Windows 7 and Windows 2008 r2 host -- when attempting to convert them to vhdx
The error should be easily reproduced by StarWind staff
Thx
v2vfans
v2vfans
Postby Oleg(staff) » Thu Jan 31, 2019 9:15 am
Unfortunately, Windows 7 and Windows 2008 are not supported by StarWind V2V converter.
Oleg(staff)
Postby v2vfans » Thu Jan 31, 2019 12:36 pm
Hi Oleg,
When you said Windows 7 and Windows 2008 are not supported - they don't seem to be entirely true.
Windows 7 / Windows 2008 r2 hosts converted to VDMK without error.
For the same Windows 7 / Windows 2008 r2 hosts, attempted conversion to VHD or VHDX however failed with the [122] error.
More importantly, the error message says "current virtual disk not supported" - it did not say conversion not supported just the virtual disk (vhd/vhdx). As mentioned above, conversion of the same hosts to VDMK format are successful.
First class vmware support and hyper-v support not as good?
Thx
v2v fans
v2vfans
Postby Oleg(staff) » Thu Jan 31, 2019 1:46 pm
The libraries needed for conversion to VHD or VHDX of OS Windows 7 / Windows 2008 are not added yet.
They should be added to the next builds.
Oleg(staff)
Postby v2vfans » Fri Feb 01, 2019 3:48 am
Thank you and look forward to the next builds.
v2v fans
v2vfans
Postby Oleg(staff) » Fri Feb 01, 2019 10:48 am
You are welcome!
Oleg(staff)
Postby smithjw5 » Mon Mar 11, 2019 4:30 pm
I get this same error whenever a .VHD file is either the source or destination. I've been using this utility since 5.6 and it has always worked well on VHD to VMDK and vice versa . I just downloaded the latest release, which is version 8, I believe. Did you receive and answer on this issue?
Documents says it supports VHD and VHDX.
smithjw5
Postby Oleg(staff) » Tue Mar 12, 2019 3:34 pm
Hi smithjw5,
Could you please provide us with the logs from V2V Converter?
Oleg(staff)
Postby atakacs » Mon Apr 29, 2019 3:28 am
Hello
Seeing the exact same issue with a Win7 machine. Is it supposed to be supported now ? If so happy to "debug" it...
atakacs
Postby Boris (staff) » Mon Apr 29, 2019 1:28 pm
https://www.starwindsoftware.com/v2v-co ... ease-notes
The latest released build was published on January, 21. So, for now no progress in Windows 7 support. Feel free to check Release Notes from time to time for an update.
Who is online
