itNinja
Fri Nov 16, 2018 12:35 pm
We have 2 different SAN's connected via iSCSI to the EXSi hosts. When I connect to any host with V2V converter I can only see a handful of datastores but can see volumes from both different types of SAN. Is there any reason why I wouldn't see all datastores?
Cheers
Sun Nov 18, 2018 6:47 am
Do you have any VM folders with .vmx descriptor files on the datastores that are missing from the list presented by V2V?
itNinja
Tue Nov 20, 2018 10:12 am
Hi Boris,
Thanks for your reply.
All datastores have the same configuration with descriptor files. Even new datastores I have created to test are not showing in V2V.
Cheers
divyamane
Tue Jun 04, 2019 7:17 am
All datastores have a similar design with descriptor records. Indeed, even new datastores I have made to test are not appearing in V2V.
