StarWind iSCSI SAN
Use of a file share for Hyper-v conversion
Postby fractal6969 » Fri Nov 09, 2018 10:32 pm
I am trying to convert a VMDK to VHDX. I am doing this with a locally copied VMDK since vSphere 6.5 is yet to be supported.
When I get to the portion of where the VHDX files are to be stored it gives me the local disk of the Hyper-v host. Is it possible to save the converted files to a file share? We are using file shares for our storage in hyper-v....not the local hyper-v disk.
thx
Fractal6969
fractal6969
Re: Use of a file share for Hyper-v conversion
Postby Oleg(staff) » Mon Nov 12, 2018 11:52 am
You should be able to save the converted files to a file share. You need to assign a letter to this share in order to have this possibility.
Oleg(staff)
Postby fractal6969 » Mon Nov 12, 2018 9:22 pm
We mapped a drive to the hyper-v host trying both "net use" and "New-PSDrive" making the drive persistent. No go. We can still only see the Local Disk under the Datastore section of the hyper-v host.
Thoughts?
fractal6969
Postby Oleg(staff) » Wed Nov 14, 2018 10:52 am
You can also try to start V2V from Hyper-V host and try conversion in a local file. The share should be available in this way.
Oleg(staff)
Postby fractal6969 » Wed Nov 14, 2018 3:40 pm
We are running 2016 Core. I'll see if the app will install and give it a shot.
fractal6969
Postby Oleg(staff) » Thu Nov 15, 2018 9:15 am
Thank you! We are waiting for your update.
Oleg(staff)
Postby fractal6969 » Mon Nov 19, 2018 10:31 pm
The application installs properly on a Windows 2016 core server. I ran a conversion from the 2016 server where the file share exists and it still only shows the local disk (C:\).
Ideas?
fractal6969
Postby Oleg(staff) » Wed Nov 21, 2018 3:27 pm
Could you please run Diskpart tool?
What is the result of List volumes?
Please share the results of this command, are you able to see the letter of share?
Oleg(staff)
Postby fractal6969 » Thu Dec 06, 2018 5:37 pm
Good morning, Oleg. When I run a list volume in diskpart it only shows 2 volumes...0 & 1. That is the c:\ drive and the system reserved drive. It doesn't show the persistent drive that we created (location of where the VM needs to go).
fractal6969
Postby Oleg(staff) » Mon Dec 10, 2018 1:42 pm
I have passed this information to our R&D team for checking.
I will keep you posted.
Oleg(staff)
Postby fractal6969 » Wed Jan 02, 2019 4:34 pm
Good morning, Oleg. Happy new year! Any news from the R&D guys?
thx
fractal6969
Postby Oleg(staff) » Fri Jan 04, 2019 8:50 am
Yes, I have news. This possibility should be added to the next build of V2V converter, should be released till the end of this month.
Oleg(staff)
Postby fractal6969 » Fri Jan 04, 2019 5:18 pm
That is great news! I will be a huge benefit to those that have large server blade farms with very little local disk. Thanks for all you guys are doing!
fractal6969
Postby Oleg(staff) » Tue Jan 08, 2019 2:08 pm
We will keep you updated with the progress.
Oleg(staff)
Postby fractal6969 » Tue Jan 22, 2019 4:18 pm
Good morning, Oleg. I'd be more than willing to test out a beta version of the software to make sure that the ability exists to use file shares. Let me know!
thx
fractal6969
Next
Who is online
Users browsing this forum: Google [Bot] and 1 guest
