Yowa
Thu Jan 26, 2017 8:02 am
i'm facing an issue when trying to convert a vmdk from a vCenter to a vhdx file. I launch the StarWind V2V Converter, fill in the Ip Address of the vCenter, Username/Password (who has access to the vCenter), and click next.
And then the app just go on a "non responding" state forever, and I cannot proceed the rest of the manipulation...
Thanks for your help.
EDIT : i'm using Starwind V2V Converter v8.0 (build 20161115) on a Windows Server 2012 R2
Michael (staff)
Thu Jan 26, 2017 10:25 am
Hello Yowa,
Current build of Starwind V2V Converter does not support connection to vCenter. You should connect to ESXi host directly.
Please let us know if it helps.
mstout
Thu Apr 06, 2017 6:49 pm
I was able to establish connectivity to a vCenter server v6.0.0, and a list of my attached storage, along with VMware images were displayed. When I chose one of them for conversion, I received the error message "The host is not licensed for this feature". Unfortunately due to security restraints, we are not allowed to login/connect directly to our ESX hosts. Will this product ever work for vCenter vs ESX host connection?
Ivan (staff)
Mon Apr 10, 2017 7:33 pm
Hello Yowa,
As Michael said above the V2V Converter does not support the vCenter. Unfortunately, you can convert VM only from local ESXi.
kienmin79
Mon Sep 18, 2017 4:05 am
Hi Ivan,
I received an error "NBD_ERR_NETWORK_CONNECT" from the V2V converter after I connected to my VMWare ESXi Server (6.5.0 (Build 5310538))->Datastore->one of the Windows 2012 (64-bit) (Esxi 5.0 or later)'s .vmdk image. Any idea what causing this problem?
Kelvin
Sergey (staff)
Mon Sep 18, 2017 9:47 am
Hello, Calvin! This error message is from ESXi.
Try to convert virtual disks one by one. Also, please try to reboot the physical host, it helped people who experienced this issue.
