Activate windows repair mode
jsente
Tue Nov 08, 2016 3:21 pm
I am using starwind v2v converter, latest release.
I need to convert an Esx5.0 image running windows server 2012.
During the conversion, I have choosed windows repair activation.
At the end of conversion, I receive an error message "failed to activate windows repair mode, unsupported os inside"
I have read the help and windows7 and above are supported.
Can you help ?
best regards
jean-claude
Michael (staff)
Thu Nov 10, 2016 4:30 pm
Hello Jean-Claude,
Please check that you have chosen the .vmdk file with OS inside. Otherwise, you will get the error mentioned in your post.
jecyled
Sun Nov 11, 2018 7:53 pm
Did you try activating it using [ ... ] or something similar?
Sun Nov 11, 2018 8:32 pm
Nope. It won't work.
