StarWind iSCSI SAN
Start Using V2V Converter
Postby milestone5077 » Fri Sep 16, 2016 4:41 pm
I have just downloaded and installed V2V converter. Hope it will help me having a good experience.
milestone5077
Re: Start Using V2V Converter
Postby Al (staff) » Mon Sep 19, 2016 6:50 pm
Hello Milestone5077,
Thank you for your post here.
We hope you will have a great experience, too :D
Al (staff)
Postby jallen213 » Fri Sep 30, 2016 10:59 pm
hi, I just converted my .vhdx file to .vmdk and was wondering why did I get two files out of one? Like one says "flat" at the end, for instances, "CHAPTERZ-PC" and the other says "CHAPTERZ-PC-flat"
jallen213
Postby John Benz » Thu Oct 06, 2016 1:09 pm
Hello jallen213
If the original VHD file was called this:
beta.sas.vhd
V2V Image converted created these two files in case when you have some issues with free space on drive.
beta-flat.vmdk (the big binary data file)
beta.sas.vmdk (the small text descriptor file)
In some other cases (like hard shut down) small text file can fall out from joint file folder.
Because of this you see both files. In yours case this can't effect on final result
jallen213 wrote:hi, I just converted my .vhdx file to .vmdk and was wondering why did I get two files out of one? Like one says "flat" at the end, for instances, "CHAPTERZ-PC" and the other says "CHAPTERZ-PC-flat"
John Benz
Postby Al (staff) » Wed Oct 12, 2016 6:52 pm
John,
Thank you for your help here.
Genleman,
Do you have any additional questions?
Al (staff)
Who is online
Users browsing this forum: No registered users and 4 guests
