StarWind iSCSI SAN
Windows 7 VM cannot run after conversion
Postby Yukio Seki » Fri Aug 12, 2016 1:18 pm
Hi
I converted VMWare VM with Windows 7 OS (one disk 20 GB, full Windows update) to Hyper-V VM. So i used V2V converter. On Hyper-V cluster I created VM with the same settings as VMWare VM.
I attached converted disk and.... nothing... bluse screen. System cannot load.
VMWare virtual machine was version 8, virtual disk was attached to SCSI (0:0). I tried to use Microsoft Virtual Machine converter... the same situation.
What is going on? V2V converter cannot converts disk attached using SCSI to IDE (hyper-V VM generation 1 for Windows 7)?
Yukio Seki
Re: Windows 7 VM cannot run after conversion
Postby Al (staff) » Fri Aug 12, 2016 3:51 pm
Hello Yukio Seki,
Thank you for your post.
Did you try to check box "Activate Windows Repair Mode" during the conversion?
Al (staff)
Who is online
