StarWind iSCSI SAN
Windows 10 - Starwind V2V Converter Wont Start
Postby dawrightau » Sun Nov 29, 2015 6:36 pm
Hi
I am running Windows 10 on a Surface Pro 3.
I would like to user your converter to convert an img file to a vhd file.
However the Startwind V2V Converter wont start. Or at least it tries to start and then stops.
Having installed the download and running it from the start menu there is a briefest glimpse of the splash screen and then it disappears. Its not really long enough to see anything. The task manager doesn't not show anything relating to starwind.
I have searched the forum and the web but cannot find anything about the problem
Is this product compatible with Windows 10? Is there something I can do to get it working?
Would be grateful for any assistance.
Regards
David
dawrightau
Re: Windows 10 - Starwind V2V Converter Wont Start
Postby Tarass (Staff) » Tue Dec 01, 2015 8:13 pm
Hi mate,
Usually, it works without any issues on Windows 10 (no idea about Surface Pro, unfortunately).
Do you see any error messages in Windows System/Application log that may somehow explain the problem?
StarWind Software Inc.
Tarass (Staff)
Who is online
