StarWind iSCSI SAN
Error opening file (2) [0]
Postby thomaselroy » Thu Jul 23, 2015 7:21 pm
I am trying to convert a vhdx to vmdk. Hyper-v 2012 to ESXi. The first screen where I pick the vhdx I get an error "Error opening file (2) [0]". Please help. Thanks.
thomaselroy
Re: Error opening file (2) [0]
Postby Vladislav (Staff) » Mon Jul 27, 2015 11:45 am
Just wondering is this file used by VM?
Vladislav (Staff)
Postby mark.reeves.78 » Tue Aug 04, 2015 6:06 pm
thomaselroy wrote:I am trying to convert a vhdx to vmdk. Hyper-v 2012 to ESXi. The first screen where I pick the vhdx I get an error "Error opening file (2) [0]". Please help. Thanks.
I am trying to do the exact same thing and have this error. As far as I know it is not in use by a VM. I am trying to think if it was in use when I copied the file off the machine. I don't believe so. It is possible. I no longer have the machine just this file is there any way to work around it?
Mark
mark.reeves.78
Postby darklight » Mon Aug 10, 2015 1:09 pm
Try to rename the file first. If it is not in use, it will allow you to do that. Then convert.
darklight
Postby Tarass (Staff) » Tue Aug 25, 2015 9:02 am
Hi guys, did the recommendation provided by darklight help?
Tarass (Staff)
Who is online
