StarWind iSCSI SAN
Error opening file (2) [3]
Postby bossofdos64 » Sat Mar 14, 2015 12:15 am
I've successfully used the converter many times before but now it no longer works when attempting to open a .vhd file.
- running StarWind V2V Converter on Windows Server 2012 R2 (have not tried that before)
- attempting to open a 1.2GB .vhd single file from local C:
- have tried "Run As Administrator"
- currently fails for ALL .vhd files
- file was on deduplicated drive but was copied locally where no dedup exists
Suggestions?
bossofdos64
Re: Error opening file (2) [3]
Postby Vitalii (staff) » Mon Mar 16, 2015 2:48 pm
This is the error "The system cannot find the path specified".
I can not say why it occurred in this case.
Can you get debug traces with DebugView to provide additional information?
Vitalii (staff)
Postby bossofdos64 » Tue Mar 17, 2015 1:47 pm
I discovered the issue involved differencing disks on a lab system and it was the "parent" disk that couldn't be found. Everything converted great once I place the "parent" disk in the correct path that the differencing was expecting.
bossofdos64
Postby Anatoly (staff) » Wed Apr 22, 2015 2:06 pm
Thank you for hte heads up!
Please let us know if there is anything else that we can help you!
[email protected]
Who is online
