StarWind iSCSI SAN
Invalid file format(10)[0] for vmdk
Postby badbob001 » Wed Nov 28, 2012 7:19 pm
From a VMware ESX Server 3i, I did a Virtaul Appliance Export of a VM, which resulted in two files: a small .OVF file and a large .VMDK file. When I have Converter open the .vmdk file, it gives the following error:
Invalid file format (10)[0]
Not all descriptor fields are present
Is that any way I can get around this issue? Alternative converters? The vmware software is from 2009 so it seems strange that it would have a vmdk format that is not yet supported.
Robert
badbob001
Re: Invalid file format(10)[0] for vmdk
Postby Anatoly (staff) » Thu Nov 29, 2012 11:16 am
Just want to let you know that currently we are trying to reproduce your issue in our test lab.
[email protected]
Postby Anatoly (staff) » Fri Nov 30, 2012 4:10 pm
I must say that unfortunately we do not work with that file format. Probably we will in the future but I cannot say exact dates.
Thank you
[email protected]
Postby Alton0 » Sat Jul 06, 2013 6:18 am
I need to convert the snapshot image (including the consolidation of the base HD image) to a VMDK file. The converter interface does not allow me to pick the .AVHD file which is my snapshot.
Alton0
Postby Anatoly (staff) » Mon Jul 15, 2013 8:56 am
Unfortunatelly we do not support this file format too. Maybe we will in the future. Stay tuned.
[email protected]
Postby savinandi » Tue Oct 01, 2013 4:42 am
I think it might gladly work in Linux. You might want to use a virtual machine if you wish or just change the OS. But I would prefer using a virtual machine to run Linux. I do not think there will be any issues in Linux. I hope this helps.
savinandi
Postby anton (staff) » Tue Oct 01, 2013 7:21 am
We'll be updating the Converter in a couple of weeks closer to V8 of StarWind released. This issue is expected to be on the fix list. FYI.
Postby Anatoly (staff) » Thu Feb 06, 2014 9:46 am
is it true ????
Well, it`s not the 1 st April, os yes, it is absolutely true :)
[email protected]
Postby ckcampbell » Wed Apr 09, 2014 6:37 pm
Any updates on this?
I just tried to convert a .vmdk extracted from a .ova and go the "Not all descriptor fields are present" error.
If there is a new version (or beta version) that solves this issue, please let me know.
Thanks.
ckcampbell
Postby Anatoly (staff) » Thu Apr 10, 2014 12:11 pm
Unfortunately we haven`t released it yet. We should have something in the end of the May.
[email protected]
Who is online
cron
