StarWind iSCSI SAN
Unable to convert vhd image
Postby bsolomon » Thu May 03, 2012 6:33 am
I am trying to convert a vhd image to vmdk. But I am getting the below error message when i select the source. Is it because the source file is corrupted? Or is there anything i need to do before i try to convert the file?
“Invalid file format (10) [2]”
Thanks in advance for your help with this.
Cheers,
Bejesh
bsolomon
Re: Unable to convert vhd image
Postby Vitalii (staff) » Thu May 03, 2012 9:11 am
It looks like the VHD you are converting have a base VHD which cannot be found.
It may happen if you moved/copied that VHD,
Vitalii (staff)
Who is online
Users browsing this forum: No registered users and 3 guests
