StarWind iSCSI SAN
Convert multipart VHD to VMDK
Postby aderuwe » Fri Aug 26, 2011 7:29 pm
I have downloaded a set of Hyper-V images. The documentation states there are 6 different virtual images in this pack. It looks like there is a "common" vhd that is used by all the images as its 27 GB. The other images are all around ~1.4 GB.
I can convert the "common" vhd, but when trying to convert the smaller, 1.4 GB files, I get this error:
Error opening file (2) [3]
I'm trying to use VMWare Workstation 7 instead of Hyper-V. Is it possible for StarWind V2V Converter to convert these types of images?
aderuwe
Re: Convert multipart VHD to VMDK
Postby aderuwe » Mon Aug 29, 2011 4:55 pm
Bump.
Anyone have an idea?
aderuwe
Postby Vitalii (staff) » Mon Aug 29, 2011 5:03 pm
The error occurs when the converter cannot find any file. But it seems that all files are in place.
Is there a source of these images, so we could download it ant test by ourselves?
Vitalii (staff)
Postby aderuwe » Mon Aug 29, 2011 5:23 pm
Yeah, the files work fine when I mount them in Hyper-V, but I'd rather use VMware.
This is the source, but the files add up to about ~10 gigs, so I don't expect you guys to troubleshoot that for me (especially for a free app). Just curious if you had any experience converting these types of Hyper-V VMs.
Thanks for the reply, by the way!
aderuwe
Postby Vitalii (staff) » Tue Aug 30, 2011 4:48 pm
I made some investigation, so there is it:
You should place the common image to the specified folder (because its position is hard coded):
C:\Temp\BTSDevCourse\VM\common\BizTalk2010Demo.vhd
This should do the job.
The image you should get, may be non-bootable,
See this thread: post11359.html#p11359 for information how to make it bootable.
Vitalii (staff)
Postby aderuwe » Tue Aug 30, 2011 6:35 pm
You are the man! I will try it later this afternoon.
Thanks so much for your help.
aderuwe
Postby anton (staff) » Wed Aug 31, 2011 10:38 am
Please keep us updated about your progress. Thank you!
Postby Vitalii (staff) » Wed Aug 31, 2011 4:35 pm
There is a bug in the converter, it will not convert the multipart VHD correctly.
I am now working on fixing it, the working version will be available soon.
Vitalii (staff)
Postby aderuwe » Wed Aug 31, 2011 4:50 pm
Yes, it did not work. I tried what you suggested and I got the error:
Error opening file (2) [5]
You guys provide amazing support for a free product. Thanks a bunch.
aderuwe
Postby Vitalii (staff) » Thu Sep 01, 2011 12:57 pm
means access violation error - some of the files is used by other application. Check it.
And then, try this version:
http://www.starwindsoftware.com/tmplink ... 110831.exe
It should correctly convert the image (if you place common image to the folder I mentioned above)
If you add this image as additional disk to any existing VM, all data should be accessible.
But when you try to boot it, it should give a blue screen (no boot device) and then reboot with a repair option. You may try make it bootable by fixing it.
I tried to run command prompt and fix it with bootsect.exe (it is in windows package), but still no success.
Please, keep me updated if you manage to boot it.
Vitalii (staff)
Who is online
