StarWind iSCSI SAN
VHD to VMDK with Linux LVM fails
Postby oweh » Wed May 25, 2011 4:08 pm
I’ve been trying V2V Image Converter to convert a Linux (CentOS) from a VHD to VMDK.
It seems to be an issue with the LVM in the OS, the boot volume is correct converted but the LVM is not correct converted. It’s not recognized by CentOS so it wont boot.
Greatul for answes
// Owe
Sweden
oweh
Re: VHD to VMDK with Linux LVM fails
Postby anton (staff) » Wed May 25, 2011 7:32 pm
It should not boot if you did not patch emulated hardware being different on Hyper-V and ESX.
oweh wrote:I’ve been trying V2V Image Converter to convert a Linux (CentOS) from a VHD to VMDK.
Greatul for answes
// Owe
Sweden
Postby oweh » Thu May 26, 2011 2:45 pm
I'm not sure I understand what you meen with "did not patch emulated hardware"
Is there anyting I can do before or after the conversion?
// Owe
oweh
Postby anton (staff) » Thu May 26, 2011 3:07 pm
Yes, you need to revert your OS to default hardware. There's a way to make Windows 7 and Windows 2008 R2 to re-query hardware. Don't know how it should be done on your Linux box.
oweh wrote:I'm not sure I understand what you meen with "did not patch emulated hardware"
// Owe
Who is online
Users browsing this forum: No registered users and 5 guests
