StarWind iSCSI SAN
.VHD to .VMDK fails Internal error (7)
Postby andrew » Tue Jun 29, 2010 2:55 pm
I have been unsuccessful in determining the meaning of "Internal error (7)" and wonder if someone can elucidate. I am attempting to convert a .vhd file to a .vmdk. I am choosing "VMWare growable image", IDE, and then selecting a file location for output.
Thanks in advance for any help.
andrew
Re: .VHD to .VMDK fails Internal error (7)
Postby Max (staff) » Wed Jun 30, 2010 11:57 am
Hello Andrew,
What is the image size you are trying to convert?
What is the sector size of the source image?
Max Kolomyeytsev
Max (staff)
Postby andrew » Thu Jul 01, 2010 8:07 pm
Max (staff) wrote:Hello Andrew,
The size of the image file is 31.5 GB.
I do not know how to find out what the sector size is on the VHD.
andrew
Postby Vitalii (staff) » Tue Jul 06, 2010 1:22 pm
Could you give me some more details:
Is it growable or pre-allocated VHD image?
Was it made by Hyper-V or Virtual PC?
The error appears after you choose output file and click "Next", right?
Vitalii (staff)
Postby andrew » Tue Jul 06, 2010 9:47 pm
OK.
More info.
I am attempting to convert P 2 V, R2 Win 2K8, as here: http://sanbarrow.com/p2v2008r2.html
P2V I used Sysinternal's Disk to VHD tool, creating a .vhd file of my running server.
I then xfer the .vhd file to a (different) running system, mount it, chkdisk it, remove unnecessary partitions, resave, and attempt to use "StarWindConvertor" to create a .vmdk of it. (The outcome is the same if I do NOT mount, chkdisk, etc)
According to StarWindConvertor, the .vhd is a "MS Virtual PC growable image".
If, during attempted conversion , I select "VMWare growable image" I get the error (7) as mentioned, regardless of SCSI or IDE choice, regardless of location of store (local, NFS, etc.)
On the other hand, if I select " ESX Server image", I then get the "File I/O error (5)" message with a zero sized .vmdk file on the storage option of my choosing.
I do not have available storage to try a VMWare Pre-allocated image, nor to try a RAW image.
Though this method has not produced a "bootable" .vmdk as yet, I have successfully created a mountable readable/writeable vmdk using WIM from the mounted .vhd, so I believe the P2V .vhd conversion to be successful.
andrew
Postby Vitalii (staff) » Fri Jul 09, 2010 12:40 pm
I'll try to reproduce it in the nearest time and see what is wrong.
Vitalii (staff)
Postby Vitalii (staff) » Fri Jul 09, 2010 3:04 pm
See PM
Vitalii (staff)
Postby andrew » Wed Jul 14, 2010 6:30 pm
Thank you for PM.
It did work for conversion.
I have still not been able to get the .vmdk to boot, but it did do the conversion.
Thank you again!
andrew
Postby Max (staff) » Wed Jul 21, 2010 2:15 pm
Andrew,
Different hypervisors are emulating different hardware, your 2k8r2 was installed on one type of hardware and now you are trying to boot it on a completely different platform. If you were using Windows PE or Live Windows this trick would have been possible.
Our task was to convert the data: we've done it :)
Max Kolomyeytsev
Max (staff)
Who is online
Users browsing this forum: No registered users and 6 guests
