bruno@e-pelzer.com wrote:Any help or idea will be very appreciated...![]()
Bruno
eyo2001 wrote:Hello all i have used Vmware converter and it usually gives you the ability do delete or retain yous snapshots, does the Starwind converter have this functionality ?
Hi folks,msebel wrote:I am having the same issue where I can not create the ESX version but can create a Workstation version. I thought maybe it was something to do with anti-virus but I have disabled it completely and recreated the vhd file. The vhd file was created on the local physical workstation that I am trying to p2v.
r2k wrote:Thanks for that link, but I've downloaded it from there tomorrow
i will check it tomorrow again.
