ways of Decommissioning and adding a server on HA
descalona
Tue Oct 10, 2023 2:38 pm
Hello all,
I have 2 servers hosting a 25TB image using starwind vsan free. I followed a guide on creating a small ha device using Create-HA_2.ps1 and extended it using ExtendDevice.ps1 scripts and I was successful. Now, I need to decom the old server and replace it with the new one without disconnecting to the image so that it still continue to run. (running a vcenter on the 25TB image) How to properly do it? I tried using Add-HAPartner.ps1 script to add the new server and sync it from the second node but I am getting a "Mandatory parameters are missed" error. Can someone able to help me with this? Herer is my Add-HAPartner.ps1 script. Thanks!
param($addr="10.0.0.202", $port=3261, $user="root", $password="starwind", $deviceName="HAImage2",
	$addr2="10.0.0.205", $port2=$port, $user2=$user, $password2=$password,
#secondary node
	$imagePath2="My computer\F\iscsi",
	$imageName2="partnerImg-hatest2-2",
	$createImage2=$true,
	$targetAlias2="hatest2-3",
	$autoSynch2=$true,
	$poolName2="pool1",
	$syncSessionCount2=1,
	$aluaOptimized2=$true,
    $hbInterface2="#p1=10.200.1.112:3260",
	$bmpType=1,
	$bmpStrategy=0,
	$bmpFolderPath="",
    $selfSyncInterface="#p2={0}:3260" -f $addr2,
    $selfHbInterface="#p2=10.200.1.114:3260"
Import-Module StarWindX
try
    $server = New-SWServer $addr $port $user $password
    $server.Connect()
	if( !$device )
		Write-Host "Device not found" -foreground red
		return
    $node = new-Object Node
    $node.HostName = $addr2
    $node.HostPort = $port2
    $node.Login = $user2
    $node.Password = $password2
    $node.ImagePath = $imagePath2
    $node.ImageName = $imageName2
    $node.CreateImage = $createImage2
    $node.TargetAlias = $targetAlias2
    $node.SyncInterface = $syncInterface2
    $node.HBInterface = $hbInterface2
	$node.AutoSynch = $autoSynch2
	$node.SyncSessionCount = $syncSessionCount2
	$node.ALUAOptimized = $aluaOptimized2
	$node.PoolName = $poolName2
	$node.BitmapStoreType = $bmpType
	$node.BitmapStrategy = $bmpStrategy
	$node.BitmapFolderPath = $bmpFolderPath
    Add-HAPartner $device $node $selfSyncInterface $selfHbInterface
catch
	Write-Host $_ -foreground red
finally
	$server.Disconnect()
Tue Oct 10, 2023 11:24 pm
please add synchronization interfaces to your script.
descalona
Wed Oct 11, 2023 12:23 pm
Hello Yaroslav,
How to add that to my script? Is it this one? It is already in the script. Please see the code.
Wed Oct 11, 2023 1:05 pm
Please modify this parameter.
descalona
Sun Oct 15, 2023 1:35 am
Hello yaroslav,
modify the parameter to what? I am a little confused. Thanks!
Sun Oct 15, 2023 1:58 am
Can you please type in the IP addresses of synchronization interfaces in the same way you did it for hbinterface? Say, 172.16.20.10 is an IP address for node 1 and 172.16.20.20 is an IP address for node 2.
Type
$syncInterface2="#p1=172.16.20.10:3260" -f $addr,
$selfSyncInterface="#p2=172.16.20.20:3260" -f $addr2,
Hope, it makes more sense now :)
Also, please make sure that synchronization and heartbeat interfaces reside on different NICs. In other words, please make sure the network redundancy requirements are met. See more at
https://www.starwindsoftware.com/best-p ... practices/ and https://www.starwindsoftware.com/system-requirements
descalona
Wed Oct 25, 2023 2:29 pm
Sorry to re-open this. But I am still having a problem. I am trying to add another partner to my already 2 node HAImage. But, I am still getting an error. Is there a way you can take a look? Thanks
PS C:\Windows\system32> param($addr="10.200.1.112", $port=3261, $user="root", $password="starwind", $deviceName="HAImage2",
	$addr2="10.200.1.114", $port2=$port, $user2=$user, $password2=$password,
#secondary node
	$imagePath2="My computer\f\iscsi",
	$targetAlias2="hatest2-2",
	$autoSynch2=$true,
	$poolName2="pool1",
	$syncInterface2="#p1=10.200.1.112:3260" -f $addr,
    $hbInterface2="#p1=10.0.0.202:3260",
	$bmpType=1,
	$bmpStrategy=0,
	$bmpFolderPath="",
    $selfSyncInterface="#p2=10.200.1.114:3260" -f $addr2,
    $selfHbInterface="#p2=10.0.0.205:3260"
try
    $server.Connect()
	if( !$device )
		return
catch
finally
descalona
Wed Oct 25, 2023 2:47 pm
Still getting "Mandatory parameters are missed"
Wed Oct 25, 2023 9:23 pm
can you try commenting everything in the script that relates to the bitmap type?
descalona
Fri Nov 03, 2023 5:47 pm
Sorry for the late reply.
I just found out from this forum that there is still no way to create a third replica from the existing 2 replica img. That is what I am trying to accomplish. Thank you so much for everything!
Sat Nov 04, 2023 6:28 am
You can reach out to support@stawind.com to help you out with the solution.
Please use this thread and 1051024 as your references.
