Issues Setting up vSAN Free with HyperV
StarWindN00b
Sat Sep 02, 2023 5:32 pm
Hello all,
I will preface this by saying I am totally new to this software. I am using the Free version as this will be a homelab deployment to see how this software works.
Setup:
2 Optiplex desktops with Server 2022 installed. Hyper-v in installed and setup.
Both are on the same domain.
Both are in the same subnet and can communicate.
I edit the CreateHA2.ps1 and run it. I have gotten to the point where I get to this error:
Request to LAB-HYPER1.DOMAIN.LOCAL ( 192.168.1.24 ) : 3261
control HAImage -CreateHeader:"" -DeviceHeaderPath:"My computer\V\masterImg21_HA.swdsk" -Type:"ImageFile_HA" -file:"imagefile1" -size:"12" -Priority:"#p0=0;#p1=1" -nodeType:"#p0=1;#p
1=1" -PartnerTargetName:"#p1=iqn.2008-08.com.starwindsoftware:192.168.1.25-partnerha22" -PartnerIP:"#p1=192.168.1.25:sync:3260:1" -IsAutoSynchEnabled:"1" -AuthChapLogin:"#p1=0b" -Aut
hChapPassword:"#p1=0b" -AuthMChapName:"#p1=0b" -AuthMChapSecret:"#p1=0b" -AuthChapType:"#p1=none" -Offset:"0" -CacheMode:"wb" -CacheSizeMB:"128" -serial:"E6D20ED65518C396" -eui64:"E6
D20ED65518C396" -revision:"0001" -product:"STARWIND" -vendor:"STARWIND" -Replicator:"#p0=0" -WitnessType:"0" -AluaAccessState:"#p0=0;#p1=0"
200 Failed: invalid partner info..
My question is, how do I decode this error message. What am I looking for here to decode what is going on?
If you need more information, let me know. I am not sure what other info you may need.
Thanks in advance!
Sat Sep 02, 2023 5:57 pm
Welcome to StarWind forum. Can I see the script you use?
StarWindN00b
Sat Sep 02, 2023 10:06 pm
Duh. My bad. here you are. Thanks for the fast reply!
param
$addr="192.168.1.24", $port=3261, $user="root", $password="starwind",
$addr2="192.168.1.25", $port2=$port, $user2=$user, $password2=$password,
#common
	$initMethod="Clear",
	$size=12,
	$sectorSize=512,
	$failover=0,
#primary node
	$imagePath="My computer\V",
	$imageName="masterImg21",
	$createImage=$true,
	$storageName="",
	$targetAlias="LAB-Hyper1",
	$autoSynch=$true,
	$poolName="pool1",
	$syncSessionCount=1,
	$aluaOptimized=$true,
	$cacheMode="wb",
	$cacheSize=128,
	$syncInterface="#p2=192.168.1.25:3260" -f $addr2,
	$hbInterface="",
	$createTarget=$true,
#secondary node
	$imagePath2="My computer\V",
	$imageName2="partnerImg22",
	$createImage2=$true,
	$storageName2="",
	$targetAlias2="partnerha22",
	$autoSynch2=$true,
	$poolName2="pool1",
	$syncSessionCount2=1,
	$aluaOptimized2=$true,
	$cacheMode2=$cacheMode,
	$cacheSize2=$cacheSize,
	$syncInterface2="#p1=192.168.1.24:3260" -f $addr,
	$hbInterface2="",
	$createTarget2=$true
Import-Module StarWindX
try
	$server.Connect()
	$firstNode = new-Object Node
	$firstNode.HostName = $addr
	$firstNode.HostPort = $port
	$firstNode.Login = $user
	$firstNode.Size = $size
	$secondNode = new-Object Node
	$secondNode.HostName = $addr2
	$secondNode.HostPort = $port2
	$secondNode.Login = $user2
		Start-Sleep -m 2000
		$device.Refresh()
catch
	Write-Host $_ -foreground red
finally
	$server.Disconnect()
Sat Sep 02, 2023 11:05 pm
Greetings,
I can see that your script misses the heartbeat.
1. comment out everything saying btmpstrategy or set one of the values.
2. try syncfromfirst instead of clear value for initmethod
3. See host syntaxes https://forums.starwindsoftware.com/vie ... p+3#p31505
See more on bitmap https://knowledgebase.starwindsoftware. ... a-devices/ see more on values you can use https://www.starwindsoftware.com/resour ... chine-cvm/ under the area where the script is discussed.
Please make sure the system satisfies network redundancy requirements https://www.starwindsoftware.com/system-requirements
StarWindN00b
Sun Sep 03, 2023 1:09 am
Maybe I am missing what is required. I think that one link you sent shows that. How many network links does this require to work. For this proof of concept, I only have 1 nic on each machine. When I move to actually use this, what is the ideal situation for this software?
I'm sorry if these are basic questions, I am new to how this works and am more familiar with other vSAN solutions.
Thank you for bearing with me.
I will look at these other suggestions as well and implement them.
StarWindN00b
Sun Sep 03, 2023 3:10 am
Alright, I have an update that is different now.
I now have 2 Nics per Optiplex. Here is my new script, and then my new error.
param
#common
	$initMethod="SyncFromFirst",
	$size=12,
	$sectorSize=512,
	$failover=0,
#primary node
	$createImage=$true,
	$storageName="",
	$autoSynch=$true,
	$poolName="pool1",
	$cacheMode="wb",
	$cacheSize=128,
	$syncInterface="#p2=10.10.10.2:3260" -f $addr2,
	$hbInterface="#p2=192.168.1.25:3260" -f $addr2,
#secondary node
	$storageName2="",
	$autoSynch2=$true,
	$poolName2="pool1",
	$syncInterface2="#p1=10.10.10.1:3260" -f $addr,
	$hbInterface2="#P1=192.168.1.24:3260" -f $addr,
try
	$server.Connect()
	#$firstNode.BitmapStoreType = $bmpType
	#$firstNode.BitmapStrategy = $bmpStrategy
	#$firstNode.BitmapFolderPath = $bmpFolderPath
	#$secondNode.BitmapFolderPath = $bmpFolderPath2
		Start-Sleep -m 2000
		$device.Refresh()
catch
finally
New Error:
Invalid channel format [2]
Sun Sep 03, 2023 10:19 pm
It is strongly recommended to use 2 physical NICs to avoid split brain (https://www.starwindsoftware.com/blog/w ... o-avoid-it). See more in the link I shared above and best practices (https://www.starwindsoftware.com/best-p ... practices/).
Please also remove write-back caching (more about caching https://knowledgebase.starwindsoftware. ... rinciples/).
Try also p (lower case) instead of upper case.
StarWindN00b
Mon Sep 04, 2023 3:22 am
OK, I'd say the P was the issue there. I made the other changes and no change from before. Followed some of the other documentation you sent and I am really having a hard time finding the issue. I'm sorry to be such a pain.
param
#common
	$size=12,
	$sectorSize=512,
	$failover=0,
#primary node
	$createImage=$true,
	$storageName="",
	$autoSynch=$true,
	$poolName="pool1",
	$cacheMode="none",
	$cacheSize=128,
    $syncInterface="#p2={0}:3261" -f "10.10.10.2",
	$hbInterface="#p2=192.168.1.25:3261",
	#$syncInterface="#p2=10.10.10.2:3260" -f $addr2,
	#$hbInterface="#p2=192.168.1.25:3260" -f $addr2,
#secondary node
	$storageName2="",
	$autoSynch2=$true,
	$poolName2="pool1",
    $syncInterface2="#p2={0}:3261" -f "10.10.10.1",
	$hbInterface2="#p2=192.168.1.24:3261",
	#$syncInterface2="#p1=10.10.10.1:3260" -f $addr,
	#$hbInterface2="#p1=192.168.1.24:3260" -f $addr,
try
	$server.Connect()
		Start-Sleep -m 2000
		$device.Refresh()
catch
finally
Error:
control HAImage -CreateHeader:"" -DeviceHeaderPath:"My computer\V\masterImg21_HA.swdsk" -Type:"ImageFile_HA" -file:"imagefile10" -size:"12" -Priority:"#p0=0;#p1=1" -nodeType:"#p0=1;#
p1=1" -PartnerTargetName:"#p1=iqn.2008-08.com.starwindsoftware:192.168.1.25-partnerha22" -PartnerIP:"#p1=10.10.10.2:sync:3261:1,192.168.1.25:heartbeat:3261:1" -IsAutoSynchEnabled:"1"
-AuthChapLogin:"#p1=0b" -AuthChapPassword:"#p1=0b" -AuthMChapName:"#p1=0b" -AuthMChapSecret:"#p1=0b" -AuthChapType:"#p1=none" -Offset:"0" -CacheMode:"none" -CacheSizeMB:"128" -seria
l:"D73CB84A4D8FB71F" -eui64:"D73CB84A4D8FB71F" -revision:"0001" -product:"STARWIND" -vendor:"STARWIND" -Replicator:"#p0=0" -WitnessType:"0" -AluaAccessState:"#p0=0;#p1=0"
Mon Sep 04, 2023 3:41 am
Please see this script once again https://forums.starwindsoftware.com/vie ... p+3#p31505
The script you sent again contains unnecessary lines. Remove these lines from your script
and
StarWindN00b
Mon Sep 04, 2023 5:30 pm
Not sure I understand what you mean? I built those lines based on the script you sent and commented out the older lines. If it is supposed to look like his script, then I should leave the lines in that you stated and removed the commented line for cleanliness. Are you saying I no longer need to tell the script which interfaces I am supposed to use for HB and Sync? Which of the below is correct?
Removed the lines and uncommented the original.
param
#common
	$size=12,
	$sectorSize=512,
	$failover=0,
#primary node
	$createImage=$true,
	$storageName="",
	$autoSynch=$true,
	$poolName="pool1",
	$cacheMode="none",
	$cacheSize=128,
#secondary node
	$storageName2="",
	$autoSynch2=$true,
	$poolName2="pool1",
try
	$server.Connect()
		Start-Sleep -m 2000
		$device.Refresh()
catch
finally
Deleted the commented out lines.
param
#common
	$size=12,
	$sectorSize=512,
	$failover=0,
#primary node
	$createImage=$true,
	$storageName="",
	$autoSynch=$true,
	$poolName="pool1",
	$cacheMode="none",
	$cacheSize=128,
#secondary node
	$storageName2="",
	$autoSynch2=$true,
	$poolName2="pool1",
try
	$server.Connect()
		Start-Sleep -m 2000
		$device.Refresh()
catch
finally
Deleted all hb and Sync interface variables.
param
#common
	$size=12,
	$sectorSize=512,
	$failover=0,
#primary node
	$createImage=$true,
	$storageName="",
	$autoSynch=$true,
	$poolName="pool1",
	$cacheMode="none",
	$cacheSize=128,
#secondary node
	$storageName2="",
	$autoSynch2=$true,
	$poolName2="pool1",
try
	$server.Connect()
		Start-Sleep -m 2000
		$device.Refresh()
catch
finally
Mon Sep 04, 2023 6:39 pm
Greetings,
The script heartbeat and sync in the first script
and the second
it had #p2={0}:3261" added.
As a reference, you can use https://forums.starwindsoftware.com/vie ... p+3#p31505.
