200 Failed: synchronizer has invalid state
networkeng123
Thu Jul 13, 2023 1:04 pm
HI,
We have a 2 node deployment which have been relocated recently and now they cant synchronise.
I get this error when I run the syncHAdeviceadvanced powershell script
200 Failed: synchronizer has invalid state..
I have updated to the latest version.
Can anyone help?
Thu Jul 13, 2023 2:59 pm
Welcome to StarWind Forum.
1. Install Management Console
2. Connect to the StarWind VSAN hosts/Control VMs.
See if any of the device mirrors are in sync.
networkeng123
Thu Jul 13, 2023 4:08 pm
No they are showing as not sync'ed.
Fri Jul 14, 2023 6:10 am
Follow this guide https://knowledgebase.starwindsoftware. ... -blackout/ (mark a node as synchronized with the script).
You might have write back cache. Consider disabling it https://knowledgebase.starwindsoftware. ... -l1-cache/.
networkeng123
Fri Jul 14, 2023 8:48 am
HI,
I have removed the caching as instructed but get the same error?
I assume the "SyncHADeviceAdvanced" script is the same as using the option in the management software?
Fri Jul 14, 2023 10:36 am
You are right but please make sure to follow the guide carefully (i.e., mark ONE NODE while partner(s) is/are down).
networkeng123
Fri Jul 14, 2023 1:06 pm
I have followed both instructions exactly, and it has made no difference.
Error when one has its starwind service disabled (I have *** out specific info):
Synchronize device *****
Failed to perform synchronization (1) from
control 0x0000016A945F7DC0 -Synchronize: -SynchronizationType:"1"
200 Failed: can't find available or valid partner for synchronization..
Error after turning off caching etc:
Device not synchronized. Synchronize current node from partner '***'
Failed to perform synchronization (1) from ***
control 0x0000016A945F7DC0 -Synchronize: -SynchronizationType:"1" -SynchronizerTargetName:"***"
Fri Jul 14, 2023 1:47 pm
You can induce the sync status manually.
1. Stop the service on both sides
2. Go to the node you would like to check first.
3. Go to the _HA.swdsk files.
4. locate the area for node id ="1" that looks like this
<sync_status>1</sync_status>
It might be
<sync_status>0</sync_status>
in your case. Set it to 1.
The area should look like this
<node id="1" name="HAImage" shut="false" active="true" flags="0">
    <storages>
      <storage_ref id="1"/>
    </storages>
    <parameters>
      <type>1</type>
      <priority>0</priority>
      <auto_sync>true</auto_sync>
      <sync_delay>50</sync_delay>
      <sync_traffic_share>50</sync_traffic_share>
      <failover_conf>0</failover_conf>
      <last_sync_snap_id>0</last_sync_snap_id>
      <alua_access_state>0</alua_access_state>
      <maintenance_mode>false</maintenance_mode>
    </parameters>
5. Start the node where you made the changes.
6. See if the storage is synchronized in Management Console.
7. Check the data.
networkeng123
Fri Jul 14, 2023 2:15 pm
I hade this:
<node id="1" name="HAImage" shut="true" active="true" flags="0">
So I updated it to the same as yours...
What about the node 2 section should this be the same?
networkeng123
Fri Jul 14, 2023 2:47 pm
Node 2 had the <sync_status>0</sync_status> so I changed it to 1, its now synchronising,
Fri Jul 14, 2023 3:01 pm
Nice to read that sync is running!
