I installed baremetal san free on my server and after doing the install started the wizard but forgot to set the timezone and now its failing with the error:
The error code is:TimeZoneId cannot be null or empty
But the buttons to retry and reset both just try to finish the wizard with bad settings. I was wondering if there is a way to reset the wizard without reinstalling and I figured you would want to know it does that for bug fixing purposes.
Thank you!
