NewGuy
Mon Nov 28, 2022 4:25 pm
Hello, trying to run through the conversion using Starwind V2V Converter 9.0.1.268
I get the attached error. To make sure I'm understanding is this saying I need to enable TLS 1.2 or is it saying I need to also DISABLE TLS 1.1 and 1.0 to upload?
Trying to get this entire server onto Azure is a single physical NON-VM server sitting on a rack far away from me. If alternative ideas are possible shout em out.
- Screen Shot of error
- 2022-11-28 10_24_23-Window.png (9.02 KiB) Viewed 2041 times
NewGuy
Thu Dec 01, 2022 7:55 am
Hello I have updated my server and enabled TLS 1.2 and DISABLED TLS 1.0 and 1.1. I am now getting this error when trying to sync with Azure.
No firewalls are enabled locally. What ports would need to be opened for this to work and I can see if they are open.
TYIA
- Error Message
- error2starwind.png (4.65 KiB) Viewed 2024 times
