techie2323
Fri Jul 08, 2022 3:30 pm
I'm trying to do a P2V migration of a server and when I try to connect to the HyperV Host that is the destination server I get an access denied message. The server is running Server 2019 Core with HyperV services.
Sun Jul 10, 2022 8:16 pm
Welcome to StarWind Forum. Check please authentication settings and make sure the user you are using has local admin privileges on the destination host.
techie2323
Mon Jul 11, 2022 2:48 pm
I was using the domain admin user account and I tried the local admin user account as well. I even tried creating a new local admin account just for this purpose and it still gave me an error. I had a look in the V2V_Log file and it's failing when it tries to access \\servername\root\virtualization\v2. If I try to access the same share using file explorer it gives me and it can't fine the share path.
Tue Jul 12, 2022 4:00 am
Is the source server running virtualized workloads? If so, can you do Hyper-V storage move between the source and destination?
techie2323
Wed Jul 13, 2022 2:42 pm
The destination is running Server 2019 Core, with HyperV and it has 5 VMs on it already. I'm trying to do a P2V of the source server. I'm sorry if I didn't make that apparent in my original post.
Thu Jul 14, 2022 10:11 am
Just to make sure we are on the same page. The server you are trying to P2V is Hyper-V Core and your destination is Windows Server/Hyper-V Core. Can you perform a storage move for a VM between the source and destination?
techie2323
Mon Jul 18, 2022 7:54 pm
I figured out that the server it running HyperV server, which isn't even a full version of Server 2019, it's a stripped down version of Server that runs HyperV in Core mode. So this my be the reason why I'm having an issue.
alaiatelas
Mon May 15, 2023 7:33 am
may we got the same problem. I'm attempting to add a newly configured host server to Hyper-V Manager.
Mon May 15, 2023 8:05 am
I am afraid you misinterpreted the problem. Could you please let more light on it?
Please also consider using CLI as described below.
