Hi all,
I'm trying to convert a VM from Azure to VMware ESXi 7.0.2 but the process ended always with the error message:
You have requested access to an area of the virtual disk that is out of bounds
I cannot understand what does it mean. I attach logs for more details:
2/14 17:54:54.953 5e20 Facility ???INFO: WrapperESXI::connect: m_url - https://10.208.1.11/sdk
2/14 17:54:54.979 5e20 Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - 524868a8-bac0-daf0-43e7-8dc62e335dd8
2/14 17:54:54.979 5e20 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsESX
2/14 17:54:55.016 5e20 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 7.0.2
2/14 17:55:17.674 5e20 Facility ???WARNING: CPPVMSettingsESX::onNext: Don't finded . in [eu1rst01__iso-tmpl] EU1VAP24/eu1vap24-osdisk-20210420-123153
2/14 17:55:17.674 5e20 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
2/14 17:55:17.689 5c48 Facility ???INFO: CPPConverting::Convert: InConvertType: 10, OutConvertType: 6
2/14 17:55:17.705 5c48 Facility ???INFO: CheckFileESX::CheckFileExistance: GetBrowser fail - File [eu1rst01__iso-tmpl] EU1VAP24 was not found
2/14 17:55:17.896 5c48 Facility ???INFO: VMConverter::ESXIConverter::CreateVM: createVM is true, 37
2/14 17:55:17.896 5c48 Facility ???INFO: CPPConverting::ConverterESX: Create VM 37
2/14 17:55:17.959 5c48 Facility ???INFO: CPPConverting::ConvertImage: pathInput: /subscriptions/ed123c5b-8c59-4053-a520-1dcdd602e1a6/resourceGroups/tms-edi-prod-rg/providers/Microsoft.Compute/disks/eu1vap24-osdisk-20210420-123153, pathOutput: [eu1rst01__iso-tmpl] EU1VAP24/eu1vap24-osdisk-20210420-123153.vmdk
2/14 17:55:18.542 5c48 Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
2/14 17:55:18.542 5c48 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [eu1rst01__iso-tmpl] EU1VAP24/eu1vap24-osdisk-20210420-123153.vmdk
2/14 17:55:18.542 5c48 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=37
2/14 17:55:18.542 5c48 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 61:5A:26:B6:A8:07:D2:5A:E4:81:E0:B2:75:DE:EF:63:CD:97:BF:8B
2/14 17:55:19.508 5c48 Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 0
2/14 18:33:26.235 5c48 Facility ???ERROR: VMwareFile::Write: m_VixDiskLib_Write is fail - 16007, You have requested access to an area of the virtual disk that is out of bounds
2/14 18:33:26.235 5c48 Facility ???ERROR: CPPConverting::ConvertImage: Write 4
2/14 18:37:36.191 5c48 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [eu1rst01__iso-tmpl] EU1VAP24/eu1vap24-osdisk-20210420-123153.vmdk
2/14 18:37:36.191 5c48 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=37
2/14 18:37:36.191 5c48 Facility ???INFO: ESXVmdk::ParseFile: Close disk
2/14 18:37:36.195 5c48 Facility ???INFO: ESXVmdk::ParseFile: Disconnect
2/14 18:37:36.195 5c48 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 61:5A:26:B6:A8:07:D2:5A:E4:81:E0:B2:75:DE:EF:63:CD:97:BF:8B
2/14 18:37:37.159 5c48 Facility ???ERROR: VMwareFile::Write: m_VixDiskLib_Write is fail - 16007, You have requested access to an area of the virtual disk that is out of bounds
2/14 18:37:37.159 5c48 Facility ???ERROR: CPPConverting::ConvertImage: Write 4
2/14 18:37:38.034 5c48 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [eu1rst01__iso-tmpl] EU1VAP24/eu1vap24-osdisk-20210420-123153.vmdk
2/14 18:37:38.034 5c48 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=37
2/14 18:37:38.034 5c48 Facility ???INFO: ESXVmdk::ParseFile: Close disk
2/14 18:37:38.034 5c48 Facility ???INFO: ESXVmdk::ParseFile: Disconnect
2/14 18:37:38.042 5c48 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 61:5A:26:B6:A8:07:D2:5A:E4:81:E0:B2:75:DE:EF:63:CD:97:BF:8B
2/14 18:37:39.005 5c48 Facility ???ERROR: VMwareFile::Write: m_VixDiskLib_Write is fail - 16007, You have requested access to an area of the virtual disk that is out of bounds
2/14 18:37:39.005 5c48 Facility ???ERROR: CPPConverting::ConvertImage: Write 4
2/14 18:37:42.109 5c48 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [eu1rst01__iso-tmpl] EU1VAP24/eu1vap24-osdisk-20210420-123153.vmdk
2/14 18:37:42.109 5c48 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=37
2/14 18:37:42.109 5c48 Facility ???INFO: ESXVmdk::ParseFile: Close disk
2/14 18:37:42.109 5c48 Facility ???INFO: ESXVmdk::ParseFile: Disconnect
2/14 18:37:42.109 5c48 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 61:5A:26:B6:A8:07:D2:5A:E4:81:E0:B2:75:DE:EF:63:CD:97:BF:8B
2/14 18:37:43.070 5c48 Facility ???ERROR: VMwareFile::Write: m_VixDiskLib_Write is fail - 16007, You have requested access to an area of the virtual disk that is out of bounds
2/14 18:37:43.070 5c48 Facility ???ERROR: CPPConverting::ConvertImage: Write 4
2/14 18:37:44.927 5c48 Facility ???WARNING: WrapperESXI::IsValidResponse: object id - 0
2/14 18:37:44.927 5c48 Facility ???ERROR: WrapperESXI::restoreDisk: IsValidResponse morVM config false
2/14 18:37:44.927 5c48 Facility ???ERROR: VMConverter::ESXIConverter::RestoreVirtualDisk: restoreDisk fail - -1
2/14 18:37:44.927 5c48 Facility ???ERROR: ESXIDisk::Delete: RestoreVirtualDisk error - Response is incorrect.
2/14 18:37:45.133 5c48 Facility ???ERROR: CPPConverting::Convert: FAILED
Please help me.
Regards.
