Error on Azure to ESX
PDXDave
Wed Dec 29, 2021 3:55 am
Trying to convert a Azure machine to VMWare. Getting this error:
12/28 19:47:57.342 92c Facility ???ERROR: VMwareFile::Write: m_VixDiskLib_Write is fail - 16007, You have requested access to an area of the virtual disk that is out of bounds
12/28 19:47:57.342 92c Facility ???ERROR: CPPConverting::ConvertImage: Write 4
Any ideas?
Wed Dec 29, 2021 9:37 am
Can I have full logs, please?
PDXDave
Wed Dec 29, 2021 7:14 pm
I don't think there is any identify information in these logs that I see.
The log file name: 'logs\V2V_Log-20211228-184458.log' (PID 1724)
12/28 18:44:58.947 e64 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
12/28 18:44:58.947 e64 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.268
12/28 18:44:58.963 e64 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
12/28 18:44:58.963 e64 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
12/28 18:44:58.963 e64 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 17763
12/28 18:44:58.963 e64 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - d3460000
12/28 18:45:02.697 e64 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eAzureConnection
12/28 18:45:19.431 e64 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
12/28 18:45:24.228 e64 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
12/28 18:45:26.072 e64 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnectionTo
12/28 18:45:40.556 e64 Facility ???INFO: WrapperESXI::connect: m_url - https://10.2.100.25/sdk
12/28 18:45:40.634 e64 Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - 524b2083-3a3d-4fe4-95c1-21c7c6ac2bc7
12/28 18:45:40.634 e64 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsESX
12/28 18:45:40.681 e64 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 6.7.0
12/28 18:46:21.368 e64 Facility ???WARNING: CPPVMSettingsESX::onNext: Don't finded . in [HIOSTOR02-003] RDS-04-003/RDS-04-003_OsDisk_1_c847e56da0e14c04bfdc901a9a55a458
12/28 18:46:21.368 e64 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
12/28 18:46:21.368 92c Facility ???INFO: CPPConverting::Convert: InConvertType: 10, OutConvertType: 6
12/28 18:46:21.509 92c Facility ???INFO: CheckFileESX::CheckFileExistance: GetBrowser fail - File [HIOSTOR02-003] RDS-04-003 was not found
12/28 18:46:21.993 92c Facility ???INFO: VMConverter::ESXIConverter::CreateVM: createVM is true, 12
12/28 18:46:21.993 92c Facility ???INFO: CPPConverting::ConverterESX: Create VM 12
12/28 18:46:22.087 92c Facility ???INFO: CPPConverting::ConvertImage: pathInput: /subscriptions/2d2d23bd-399d-488c-a46b-03e80307931d/resourceGroups/TSONGASRG/providers/Microsoft.Compute/disks/RDS-04-003_OsDisk_1_c847e56da0e14c04bfdc901a9a55a458, pathOutput: [HIOSTOR02-003] RDS-04-003/RDS-04-003_OsDisk_1_c847e56da0e14c04bfdc901a9a55a458.vmdk
12/28 18:46:22.650 92c Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
12/28 18:46:22.696 92c Facility ???INFO: ESXVmdk::ParseFile: sFilename - [HIOSTOR02-003] RDS-04-003/RDS-04-003_OsDisk_1_c847e56da0e14c04bfdc901a9a55a458.vmdk
12/28 18:46:22.696 92c Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=12
12/28 18:46:22.712 92c Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 1B:1B:4B:1F:00:0E:38:DB:8F:93:98:E9:72:43:64:03:AF:7B:40:B2
12/28 18:46:23.775 92c Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 0
12/28 19:54:17.885 92c Facility ???INFO: ESXVmdk::ParseFile: sFilename - [HIOSTOR02-003] RDS-04-003/RDS-04-003_OsDisk_1_c847e56da0e14c04bfdc901a9a55a458.vmdk
12/28 19:54:17.885 92c Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=12
12/28 19:54:17.885 92c Facility ???INFO: ESXVmdk::ParseFile: Close disk
12/28 19:54:17.885 92c Facility ???INFO: ESXVmdk::ParseFile: Disconnect
12/28 19:54:17.901 92c Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 1B:1B:4B:1F:00:0E:38:DB:8F:93:98:E9:72:43:64:03:AF:7B:40:B2
12/28 19:54:18.744 92c Facility ???ERROR: VMwareFile::Write: m_VixDiskLib_Write is fail - 16007, You have requested access to an area of the virtual disk that is out of bounds
12/28 19:54:18.744 92c Facility ???ERROR: CPPConverting::ConvertImage: Write 4
12/28 20:01:31.288 92c Facility ???INFO: ESXVmdk::ParseFile: sFilename - [HIOSTOR02-003] RDS-04-003/RDS-04-003_OsDisk_1_c847e56da0e14c04bfdc901a9a55a458.vmdk
12/28 20:01:31.288 92c Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=12
12/28 20:01:31.288 92c Facility ???INFO: ESXVmdk::ParseFile: Close disk
12/28 20:01:31.288 92c Facility ???INFO: ESXVmdk::ParseFile: Disconnect
12/28 20:01:31.319 92c Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - 1B:1B:4B:1F:00:0E:38:DB:8F:93:98:E9:72:43:64:03:AF:7B:40:B2
12/28 20:01:32.304 92c Facility ???ERROR: VMwareFile::Write: m_VixDiskLib_Write is fail - 16007, You have requested access to an area of the virtual disk that is out of bounds
12/28 20:01:32.304 92c Facility ???ERROR: CPPConverting::ConvertImage: Write 4
12/28 20:07:34.094 92c Facility ???WARNING: WrapperESXI::IsValidResponse: object id - 0
12/28 20:07:34.094 92c Facility ???ERROR: WrapperESXI::restoreDisk: IsValidResponse morVM config false
12/28 20:07:34.094 92c Facility ???ERROR: VMConverter::ESXIConverter::RestoreVirtualDisk: restoreDisk fail - -1
12/28 20:07:34.094 92c Facility ???ERROR: ESXIDisk::Delete: RestoreVirtualDisk error - Response is incorrect.
12/28 20:07:34.547 92c Facility ???ERROR: CPPConverting::Convert: FAILED
12/28 20:09:27.921 e64 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocation
12/28 20:09:29.312 e64 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eAzureConnection
12/28 20:09:30.280 e64 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
12/28 20:09:35.515 e64 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
12/28 20:09:37.390 e64 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnectionTo
12/28 20:09:38.155 e64 Facility ???WARNING: WrapperESXI::disconnect: m_proxy->Logout fail - 12
12/28 20:09:38.155 e64 Facility ???ERROR: getErrorFromSOAP: soap_sprint_fault - SOAP 1.1 fault "":ServerFaultCode [no subcode]
Detail:
12/28 20:09:38.171 e64 Facility ???INFO: WrapperESXI::connect: m_url - https://10.2.100.25/sdk
12/28 20:09:38.234 e64 Facility ???INFO: WrapperESXI::connect: fullName - Administrator, key - 5287ef5c-7056-a44e-11e7-addfa9a9e842
12/28 20:09:38.234 e64 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsESX
12/28 20:09:38.265 e64 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 6.7.0
12/28 20:09:52.530 e64 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eESXConnectionTo
12/28 20:09:53.265 e64 Facility ???INFO: ICPPage::OnWizardBack: SetActivePage - eLocationTo
Thu Dec 30, 2021 3:12 pm
Thanks for your logs. We will keep you posted on the log investigation.
Tue Jan 04, 2022 6:12 am
Can you try converting the disk alone, please?
