SMI-S Config & Thin Provision
caz3542
Fri Jan 23, 2015 2:39 am
When configuring the SMI-S provider, what what is the easiest way (i.e. to avoid errors) to:
1) Create additional concrete pools
2) Configure the image type to be thin provisioning instead of thick.
Also, is there a XML config guide available to guide potential configuration changes?
Yuriy (staff)
Tue Jan 27, 2015 12:11 pm
caz3542,
You can do this only through direct editing of smis-config.xml file.
There is no any document for this operation, but it very simple to understand.
You can change type of the pool using a StarWindSMI-SConfugurator.exe application.
