Had a similar problem, but I disable dedup, to see if that was the problem. But now I know its an LSFS problem.
made an LSFS LUN 1.17TB,
created VM disk of 1024MB,
copy 500GB of documents to this disk,
Now in my VM that is using this LUN, on the disk I have 557GB Free, but on the iSCSI physical disk it say I used 1.2TB,
- lsfs_size_on_disk.png (94.31 KiB) Viewed 33939 times
This seem strange to me, so I right-click the disk in my VM and select properties, used=466GB, free=557GB, total=0.99TB,
but my backup software says it copied 757GB of data and it should also keep a copy of all old documents for 3 months.
- lsfs_size_on_disk2.png (211.32 KiB) Viewed 33939 times
This was not adding up, so I went into the disk (drive E:) and did a Ctrl+A in the root of that drive, the right-click, then select properties
that's when I remember that I had enabled compression and dedup inside the VM(file server with win2012R2).
This is somewhat brain-mashing, I have:
1.1M Files
77K Folders
size of all files = 814GB
size of all files on Disk = 6.02GB
I for one can not explain all these different numbers/reading, so am looking for a way to get back some of the free space on my iSCSI Physical Disks, and I found 2:
1) sdelete v1.61 (non-gui)
http://technet.microsoft.com/en-us/sysi ... 97443.aspx
2) perfectstorage [ ... ]
I am going to try them, to see which is better.
