Beta-1 of V8
awedio
Mon Jan 07, 2013 7:11 am
According to Anton (in another thread) "...it's something you'll have in this January so make sure you apply for Beta-1 of V8"
When & where do we apply for this?
http://www.starwindsoftware.com/forums/ ... t3029.html
Alex (staff)
Wed Jan 09, 2013 3:59 pm
Beta of V8 is planned for the end of January or February.
If you are registered for beta-testing program, you'll receive the letter about new version when beta testing for v8 starts.
You can register here:
http://www.starwindsoftware.com/beta-testing-program
Alexey.
awedio
Mon Feb 04, 2013 2:48 pm
When is the "new" ETA?
Tue Feb 05, 2013 8:47 am
We have it actually. But current performance results are disgusting to say at least so we're not going to leak it to public w/o at least basic homework applied.
Be prepared for a week or so...
awedio wrote:When is the "new" ETA?
awedio
Wed Feb 27, 2013 4:49 pm
The new ETA is....?
Wed Mar 06, 2013 5:05 pm
I hope we`ll have it until the end of this month
sunyucong
Sun Apr 07, 2013 5:32 am
well, it's now April, any news?
Mon Apr 08, 2013 10:32 am
Yup - ETA moved to the end of May or the beginning of June :)
We are working hard to give our users a really good product, and this is not the most simple task, I hope we are on the same page on this.
Thank you for your understanding.
Fri Sep 06, 2013 1:27 pm
So beginning of June turned to be a beginning of September. Beta is out. Enjoy!
http://www.starwindsoftware.com/forums/ ... t3306.html
turkina
Fri Sep 06, 2013 2:59 pm
Awesome!
Has VAAI been re-enabled in v8?
Alex (staff)
Fri Sep 06, 2013 3:00 pm
Yes, VAAI is enabled for all devices.
Alexey.
lohelle
Fri Sep 06, 2013 6:17 pm
It looks like the L2-cache is always created in the storage-pool location, and not in the location selected in the wizard.
Alex (staff)
Mon Sep 09, 2013 8:13 am
Thanks, we are fixing this and a couple of other issues.
Alexey.
lohelle
Mon Sep 23, 2013 8:46 pm
hope this is fixed (delete support)
Tested on ESXi 5.1 and 5.5
Command:
esxcli storage core device vaai status get
Output:
eui.3c750b4679ddb0b1
VAAI Plugin Name:
ATS Status: supported
Clone Status: supported
Zero Status: supported
Delete Status: unsupported
eui.689cf0483bc0b9f8
VAAI Plugin Name:
Mon Sep 23, 2013 8:52 pm
we'll do
did you check actual vaai infruence on your systems?
especially ats
