jpcapone
Sat Nov 20, 2021 3:13 am
I have been stumbling through the set up process for StarWind VTL free and I am down to configuring replication to Azure blob storage. Can someone please help me to understand what values should be used for the following variables in the VTLReplicationSettings script:
$accessKey= # is this under Access keys/key1
$secretAccessKey="YourSecretKey" #I dont know what this correlates to in Azure Lingo
$regionName="region", # would this be "East US"?
$serviceUrl= # is this under Endpoints file service i.e. https://{Container_Name}.file.core.windows.net/
$target=16 # I am assuming this is correct as the replication target is azure
Thanks in advance!!
Sat Nov 20, 2021 6:32 pm
Welcome to StarWind Forum.
Yes.
This is for AWS
This can be selected per your preference
This is for AWS.
jpcapone
Sat Nov 20, 2021 7:19 pm
Thank you.
I guess I am a but confused now. Since the serviceurl is for AWS how does StarWind VTL know what to connect to in Azure? I mean it seems that the only thing that wouid refer to the blob storage endpoint is the accesskey. is that enough information for StarWind VTL to connect to Azure Blob storage?
Looks like containerName refers to the actual container. Are there any examples of this script being used for Azure blob storage or which variables are required?
$deviceName="vtl1",
$target=[StarWindVtlReplicationTarget]::REPLICATION_TARGET_S3,
$accessKey="<redacted>",
$secretAccessKey="<redacted>",
$regionName="us-east-1",
$containerName="off-site-backup",
jpcapone
Sat Nov 20, 2021 8:21 pm
thanks for the reply.
are you referring to this:
If so what would be an example of what should go in the target name field?
jpcapone
Sat Nov 20, 2021 9:30 pm
I am little bit confused. Using the following as an example (from the CreateVirtualTapeLibrary.ps1 script) where would i put the target name for the initiator?
$deviceName="VTL1",
$target=16,
$accessKey="Access key from Azure",
#$secretAccessKey="YourSecretKey",
$regionName="East US",
$containerName="TestBlobContainer",
#$serviceUrl="", # S3 Generic clouds only
Mon Nov 22, 2021 11:38 am
Sorry for misleading. Target is the destination for the VTL offload.
# $target=2 #[StarWindVtlReplicationTarget]::REPLICATION_TARGET_S3
# $target=4 #[StarWindVtlReplicationTarget]::REPLICATION_TARGET_BACKBLAZE
# $target=16 #[StarWindVtlReplicationTarget]::REPLICATION_TARGET_AZURE
# $target=32 #[StarWindVtlReplicationTarget]::REPLICATION_TARGET_S3GENERIC
