It so happened that the administrator of the remote OU removed StarWind on both nodes. After reinstallation, there is no target or disk in the console. I took StarWind.cfg from other servers with similar configuration. After that, all disks appeared in the console, but synchronization does not work. When I try to run the synchronization script, SyncHaDeviceAdvanced displays the message:
200 Failed: connсection with partner node is invalid ..
Also in the console writes synchronization and hertbeat channel is down. Tell me how to restore the configuration without losing data?
log
https://sondisp.zdrav.admin-smolensk.ru/pics/log.log
cfg
https://sondisp.zdrav.admin-smolensk.ru ... rWind1.txt
https://sondisp.zdrav.admin-smolensk.ru ... rWind2.txt
