tryllz
Sat Jul 24, 2021 3:08 pm
I have the free NAS and SAN storage appliance and in the initial configuration the vCenter plugin failed with the error refused to connect. Once the configuration completed, even from within the settings page I'm unable to connect.
Is the vCenter plugin available for the Free license ?
tryllz
Sat Jul 24, 2021 5:49 pm
Both vCenter and Storage can ping each other.
vCenter - w-vcsa-sddc / 192.168.10.40
Storage - d-nas-strg-01 / 10.0.20.70
root@w-vcsa-sddc [ ~ ]# ping 10.0.20.70
PING 10.0.20.70 (10.0.20.70) 56(84) bytes of data.
64 bytes from 10.0.20.70: icmp_seq=1 ttl=62 time=1.83 ms
64 bytes from 10.0.20.70: icmp_seq=2 ttl=62 time=2.39 ms
64 bytes from 10.0.20.70: icmp_seq=3 ttl=62 time=1.92 ms
^C
--- 10.0.20.70 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 6ms
rtt min/avg/max/mdev = 1.831/2.047/2.388/0.243 ms
root@w-vcsa-sddc [ ~ ]# exit
user@d-nas-strg-01:~$ ping 192.168.10.40
PING 192.168.10.40 (192.168.10.40) 56(84) bytes of data.
64 bytes from 192.168.10.40: icmp_seq=1 ttl=62 time=1.89 ms
64 bytes from 192.168.10.40: icmp_seq=2 ttl=62 time=2.16 ms
^C
--- 192.168.10.40 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1001ms
rtt min/avg/max/mdev = 1.893/2.028/2.163/0.135 ms
tryllz
Mon Jul 26, 2021 4:44 am
Sorry to update again,
I had done the test setup in VMware Workstation and it worked, but now when I try setting up on an ESXi server it wouldn't work, same issue as before.
The ESXi version is ESXi-7.0U2a-17867351
tryllz
Mon Jul 26, 2021 6:08 am
yaroslav (staff) wrote:You were still not able to connect to vCenter?
I'm afraid no, the steps mentioned in both links do not work when StarWind SAN and NAS is installed as a VM on ESXi.
myrandor
Mon Jul 26, 2021 1:50 pm
For my side, it doesn't work because the jquery library doesn't get loaded.
On the source of the page, the library is included as "assets/jquery.js" which results as a 404 when in the folder "/starwindplugin/setup/"
The correct path should be "/assets/jquery.js".
I tried to change this file:
/opt/VSAManagementConsole/InterfaceProviders/VSAManagement/WebService/Views/Shared/_Layout.cshtml
But even after re-starting the services, nothing changes. I suspect the link is compiled inside some DLLs...
tryllz
Mon Jul 26, 2021 2:34 pm
yaroslav (staff) wrote:Colleagues,
Did you try re-deploying the VM?
I have deployed more than 1 Storage Appliance more than once, did not work.
