StarWind VSAN Free
fritte
Tue Jun 15, 2021 8:28 am
Hey,
i got a problem with my VSAN konfiguration.
Created two HA Devices like described in
https://www.starwindsoftware.com/resour ... rver-2016/
Problem is, my HA Devices doesnt´t sync anymore after shutdown of both nodes.
Jumbo Packet is on 9014 Bytes
Import-Module StarWindX
try
    #specify the IP address and credential (this is default cred) of a first node
    $server.Connect()
    $firstNode = new-Object Node
    # Specify the path where image file is stored
    $firstNode.ImagePath = "My computer\D\"
    # Specify the image name
    $firstNode.ImageName = "Data"
    # Size of the image
    $firstNode.Size = 6144000
    # Create the image
    # iSCSI target alias (lower case only supported because of RFC)
    $firstNode.TargetAlias = "data"
    # Synchro auto ?
    $firstNode.AutoSynch = $true
    # partner synchronization interface (second node)
    $firstNode.SyncInterface = "#p2=172.16.20.20:3260"
    # partner heartbeat interface (second node)
    $firstNode.HBInterface = "#p2=172.16.10.20:3260"
    # cache size
    $firstNode.CacheSize = 64
    # cache mode (write-back cache)
    $firstNode.CacheMode = "wb"
    # storage pool name
    $firstNode.PoolName = ""
    # synchronization session count. Leave this value to 1
    # ALUA enable or not
    $firstNode.SectorSize = 4096
    # 'SerialID' should be between 16 and 31 symbols. If it not specified StarWind Service will generate it.
    # Note: Second node always has the same serial ID. You do not need to specify it for second node
    # $firstNode.SerialID = "050176c0b535403ba3ce02102e33eab"
    $secondNode = new-Object Node
    $secondNode.HostName = "192.168.120.49"
    $secondNode.HostPort = "3261"
    $secondNode.Login = "root"
    $secondNode.ImagePath = "My computer\D\"
    $secondNode.ImageName = "Data"
    $secondNode.Size = 6144000
    $secondNode.TargetAlias = "data"
    $secondNode.AutoSynch = $true
    # First node synchronization IP address
    $secondNode.SyncInterface = "#p1=172.16.20.10:3260"
    # First node heartbeat IP address
    $secondNode.HBInterface = "#p1=172.16.10.10:3260"
    $syncState = $device.GetPropertyValue("ha_synch_status")
    while ($syncState -ne "1")
        # Refresh device info
        $device.Refresh()
        Start-Sleep -m 2000
catch
    Write-Host "Exception $($_.Exception.Message)" -foreground red
$server.Disconnect()
Someone got a solution maybe for that problem? Would be great
Tue Jun 15, 2021 8:41 am
Welcome to StarWind Forum. Something similar was reported here https://forums.starwindsoftware.com/vie ... ync#p32682
Good script is here https://forums.starwindsoftware.com/vie ... p+3#p31505.
fritte
Tue Jun 15, 2021 9:24 am
yaroslav (staff) wrote:Welcome to StarWind Forum. Something similar was reported here https://forums.starwindsoftware.com/vie ... ync#p32682
Thanks for your answer, i tryed to add the managment IP to Heatbeat like written in the Articel, no change.
Now when i want to create a new HA its stuck at 0%
There was a thread there "https://forums.starwindsoftware.com/vie ... 5&start=15" about it.
Need i change something in the config .cfg file in starwind folder?
Node01:
192.168.120.48 second HB + Managment
172.16.20.10 Sync
172.16.10.10 HB
Node02:
192.168.120.49 second HB+ Managment
172.16.20.20 sync
172.16.10.20 HB
I use Intel X710 10Gbit Network Card.
Tue Jun 15, 2021 9:47 am
Please make sure to use IPs of the second server under the Primary Node section and IPs of the first one under the Secondary Node.
fritte
Tue Jun 15, 2021 10:04 am
yaroslav (staff) wrote:Please make sure to use IPs of the second server under the Primary Node section and IPs of the first one under the Secondary Node.
Check, everything allright.
$firstNode.HBInterface = "#p2=172.16.10.20:3260,192.168.120.49:3260"
$secondNode.HBInterface = "#p1=172.16.10.10:3260,192.168.120.48:3260"
Wed Jun 16, 2021 8:07 am
What is the size of the device you are trying to create? Try creating a 1 GB volume and then extending it with the script.
fritte
Wed Jun 16, 2021 9:26 am
yaroslav (staff) wrote:What is the size of the device you are trying to create? Try creating a 1 GB volume and then extending it with the script.
i want to create a Witness for Cluster with size 2048mb at first, but fails
Thu Jun 17, 2021 5:25 pm
Cann I have the entire script, please?
fritte
Fri Jun 18, 2021 7:29 am
yaroslav (staff) wrote:Cann I have the entire script, please?
sure
try
    $server = New-SWServer -host 192.168.120.48 -port 3261 -user root -password starwind
    $server.Connect()
    $firstNode.ImageName = "Zeuge"
    # Size of the image
    $firstNode.Size = 2048
    # Create the image
    $firstNode.TargetAlias = "zeuge"
    # Synchro auto ?
    # cache size
    # storage pool name
    $secondNode.ImageName = "Zeuge"
    $secondNode.Size = 2048
    $secondNode.TargetAlias = "zeuge"
        $device.Refresh()
        Start-Sleep -m 2000
catch
Node01:
172.16.20.10 Sync
172.16.10.10 HB
Node02:
172.16.20.20 sync
172.16.10.20 HB
Mon Jun 21, 2021 8:33 am
It seems you are using script in a wrong way.
Remove the imgs and headers from D:\ and try configuring this part
param($addr="192.168.0.1", $port=3261, $user="root", $password="starwind",
	$addr2="192.168.0.2", $port2=$port, $user2=$user, $password2=$password,
#common
	$initMethod="Clear",
	$size=12,
	$sectorSize=512,
	$failover=0,
#primary node
	$imagePath="My computer\C\starwind",
	$imageName="masterImg21",
	$createImage=$true,
	$storageName="",
	$targetAlias="targetha21",
	$autoSynch=$true,
	$poolName="pool1",
	$syncSessionCount=1,
	$aluaOptimized=$true,
	$cacheMode="wb",
	$cacheSize=128,
	$syncInterface="#p2={0}:3260" -f $addr2,
	$hbInterface="",
	$createTarget=$true,
#secondary node
	$imagePath2="My computer\C\starwind",
	$imageName2="partnerImg22",
	$createImage2=$true,
	$storageName2="",
	$targetAlias2="partnerha22",
	$autoSynch2=$true,
	$poolName2="pool1",
	$syncSessionCount2=1,
	$aluaOptimized2=$false,
	$cacheMode2=$cacheMode,
	$cacheSize2=$cacheSize,
	$hbInterface2="",
	$createTarget2=$true
Try this script
param($addr="192.168.120.48", $port=3261, $user="root", $password="starwind",
	$addr2="192.168.120.49", $port2=$port, $user2=$user, $password2=$password,
#common
	$size=1024,
	$sectorSize=4096,
	$failover=0,
#primary node
	$imagePath="My computer\D\",
	$createImage=$true,
	$storageName="",
	$autoSynch=$true,
	$poolName="pool1",
	$cacheMode="none",
	$cacheSize=128,
	$syncInterface="#p2=172.16.20.20:3260" -f $addr2,
	$hbInterface="172.16.10.20,192.168.120.49" -f $addr2,
#secondary node
	$imagePath2="My computer\D\",
	$storageName2="",
	$autoSynch2=$true,
	$poolName2="pool1",
	$syncInterface2="#p1=172.16.20.10:3260" -f $addr,
	$hbInterface2="172.16.10.10,192.168.120.48" -f $addr,
try
	Enable-SWXLog
	$server.Connect()
	$firstNode.HostName = $addr
	$firstNode.HostPort = $port
	$firstNode.Login = $user
	$firstNode.Size = $size
	$secondNode.HostName = $addr2
	$secondNode.HostPort = $port2
	$secondNode.Login = $user2
		Start-Sleep -m 2000
		$device.Refresh()
catch
	Write-Host $_ -foreground red
finally
Something similar was reported here viewtopic.php?f=5&t=5815&p=32682&hilit=sync#p32682
Refer to this script viewtopic.php?f=5&t=5624&p=31505&hilit=tip+3#p31505.
fritte
Mon Jun 21, 2021 2:31 pm
yaroslav (staff) wrote:It seems you are using script in a wrong way.
#common
	$size=12,
	$sectorSize=512,
	$failover=0,
#primary node
	$createImage=$true,
	$storageName="",
	$autoSynch=$true,
	$poolName="pool1",
	$cacheMode="wb",
	$cacheSize=128,
	$hbInterface="",
#secondary node
	$storageName2="",
	$autoSynch2=$true,
	$poolName2="pool1",
	$hbInterface2="",
Try this script
#common
	$size=1024,
	$sectorSize=4096,
	$failover=0,
#primary node
	$createImage=$true,
	$storageName="",
	$autoSynch=$true,
	$poolName="pool1",
	$cacheMode="none",
	$cacheSize=128,
#secondary node
	$storageName2="",
	$autoSynch2=$true,
	$poolName2="pool1",
try
	Enable-SWXLog
	$server.Connect()
		Start-Sleep -m 2000
		$device.Refresh()
catch
finally
I tryed your script, which doesnt work "Invalid channel format [2]"
Copied the Script from your Reference, changed some but fails too
#common
   $size=1024,
   $sectorSize=4096,
   $failover=0,
#primary node
   $imagePath="My computer\D",
   $createImage=$true,
   $storageName="",
   $autoSynch=$true,
   $poolName="pool1",
   $cacheMode="wb",
   $cacheSize=128,
   $hbInterface="#p2=172.16.10.20:3260,192.168.120.49:3260" -f $addr2,
#secondary node
   $imagePath2="My computer\D",
   $storageName2="",
   $autoSynch2=$true,
   $poolName2="pool1",
   $aluaOptimized2=$true,
   $hbInterface2="#p1=172.16.10.10:3260,192.168.120.48:3260" -f $addr,
    try
       Enable-SWXLog
       $server.Connect()
          Start-Sleep -m 2000
          $device.Refresh()
    catch
    finally
again it says there no nics aviable which is false, there are
The imagefile it creates on both nodes but theres no sync, i checked your linked topic about a similar error, yea its similar, but i cant find my issue in my situation
Antwort von 172.16.20.20: Bytes=32 Zeit<1ms TTL=128
Antwort von 172.16.10.20: Bytes=32 Zeit<1ms TTL=128
Mon Jun 21, 2021 6:09 pm
Contact us at support@starwind.com. Please use this thread and 527928 as a reference.
fritte
Thu Jul 15, 2021 6:53 am
yaroslav (staff) wrote:Contact us at support@starwind.com. Please use this thread and 527928 as a reference.
Hi yaroslav,
thanks for your support, after disabling iSCSI Targetserver and Fileserver Role everything is working fine.
So if someone got the same issue, above is the solution
After that, i´v got a another problem, maybe someone had the same issue, google didnt helped
One VM is running on ClusterSharedVolume (CSV) and i tested the performance. Read speed is fine, but write speed is slow.
Maybe someone got a solution for that
Thu Jul 15, 2021 9:11 am
You are always welcome.
Is that happening for 1 VM? I'd like to see underlying storage tests vs. CSV. See the recommended testing methodology here https://www.starwindsoftware.com/best-p ... practices/.
Also, make sure to have the Fixed disks for that VM.
fritte
Mon Jul 19, 2021 1:01 pm
yaroslav (staff) wrote:Hi,
I only have currently one VM on the cluster, tested a new one, same issue.
172.16.20.20 (sync) Benchmark on Hypervisor
[SUM]   0.00-10.00  sec  11.0 GBytes  9.41 Gbits/sec                  sender
[SUM]   0.00-10.00  sec  10.9 GBytes  9.41 Gbits/sec                  receiver
172.16.10.20 (hbinit) Benchmark on Hypervisor
[SUM]   0.00-10.00  sec  10.9 GBytes  9.40 Gbits/sec                  sender
[SUM]   0.00-10.00  sec  10.9 GBytes  9.40 Gbits/sec                  receiver
Hypervisor Knoten 02 Raid5:
[Read]
  SEQ    1MiB (Q=  8, T= 1): 14784.792 MB/s [  14099.9 IOPS] <   567.01 us>
  SEQ    1MiB (Q=  1, T= 1):  7487.309 MB/s [   7140.5 IOPS] <   139.80 us>
  RND    4KiB (Q= 32, T= 1):   574.406 MB/s [ 140235.8 IOPS] <   226.72 us>
  RND    4KiB (Q=  1, T= 1):    25.074 MB/s [   6121.6 IOPS] <   163.12 us>
[Write]
  SEQ    1MiB (Q=  8, T= 1):  2178.587 MB/s [   2077.7 IOPS] <  3833.38 us>
  SEQ    1MiB (Q=  1, T= 1):  2154.981 MB/s [   2055.2 IOPS] <   483.76 us>
  RND    4KiB (Q= 32, T= 1):   516.900 MB/s [ 126196.3 IOPS] <   245.41 us>
  RND    4KiB (Q=  1, T= 1):   126.083 MB/s [  30782.0 IOPS] <    32.30 us>
Virtual Machine Test on CSV:
[Read]
  SEQ    1MiB (Q=  8, T= 1):  6210.557 MB/s [   5922.8 IOPS] <  1346.99 us>
  SEQ    1MiB (Q=  1, T= 1):  3628.800 MB/s [   3460.7 IOPS] <   287.93 us>
  RND    4KiB (Q= 32, T= 1):   367.757 MB/s [  89784.4 IOPS] <   355.49 us>
  RND    4KiB (Q=  1, T= 1):    35.786 MB/s [   8736.8 IOPS] <   113.87 us>
[Write]
  SEQ    1MiB (Q=  8, T= 1):   125.046 MB/s [    119.3 IOPS] < 58533.24 us>
  SEQ    1MiB (Q=  1, T= 1):   100.933 MB/s [     96.3 IOPS] < 10376.80 us>
  RND    4KiB (Q= 32, T= 1):    94.868 MB/s [  23161.1 IOPS] <  1380.04 us>
  RND    4KiB (Q=  1, T= 1):     6.280 MB/s [   1533.2 IOPS] <   650.75 us>
Test on HADevice mounted on one node:
[Read]
  SEQ    1MiB (Q=  8, T= 1):  2802.211 MB/s [   2672.4 IOPS] <  2990.68 us>
  SEQ    1MiB (Q=  1, T= 1):   556.583 MB/s [    530.8 IOPS] <  1882.40 us>
  RND    4KiB (Q= 32, T= 1):   314.350 MB/s [  76745.6 IOPS] <   413.13 us>
  RND    4KiB (Q=  1, T= 1):     8.352 MB/s [   2039.1 IOPS] <   489.83 us>
[Write]
  SEQ    1MiB (Q=  8, T= 1):   340.181 MB/s [    324.4 IOPS] < 23333.82 us>
  SEQ    1MiB (Q=  1, T= 1):   489.050 MB/s [    466.4 IOPS] <  2140.08 us>
  RND    4KiB (Q= 32, T= 1):   187.068 MB/s [  45670.9 IOPS] <   699.73 us>
  RND    4KiB (Q=  1, T= 1):     6.639 MB/s [   1620.8 IOPS] <   615.50 us>
Least Queue Depth MPIO policy is set on storage.
