What IP addresses are you using to connect your HA device in the MS iSCSI initiator in both sides?NoName wrote:Ok. I understand. But now i try to configure only HA cluster, without Failover cluster. So a problem not in it.
@ziz (staff) wrote:What IP addresses are you using to connect your HA device in the MS iSCSI initiator in both sides?
Please check that in the MS iSCSI initiator of both of your servers you indicate the IP addresses of the both servers (do not use loopback 127.0.0.1).NoName wrote:@ziz (staff) wrote:What IP addresses are you using to connect your HA device in the MS iSCSI initiator in both sides?
Look, i have two servers with Starwind targets. On the same servers i run ISCSI initiator and connect them. Addresses of HA servers appear automatically on the Discovery Tab. One address - Synchronization; one address - Heartbeat; One address - another node sync.interface. Maybe this solution is wrong, but i dont have hardware anymore in my home.
Yes. Adresses of the both servers there is. No loopback. One target connected automatically, but it is not appears on the Favorit Tab and Volumes and Device after AutoConfigure. Look please at a screenshot.@ziz (staff) wrote: Please check that in the MS iSCSI initiator of both of your servers you indicate the IP addresses of the both servers (do not use loopback 127.0.0.1).
In the MS iSCSI initiator on both sides you have to connect both "test" and "testpartner".NoName wrote:@ziz (staff) wrote: [ ... ]
Is it normal situation?
Ok. That's right. I only wanted to know, why they are connected automatically?@ziz (staff) wrote: In the MS iSCSI initiator on both sides you have to connect both "test" and "testpartner".
Yes. All rights and ports are opened and configured. Problems begin when i disconnect a client from target for services. After connection restoration, one HA node is out of sync and can't be synchronized never. Only after rebuild target.@ziz (staff) wrote: Regarding the sync issue, you should check that the firewalls are disabled on both servers or that you have exceptions for ports 3260. Check that in StarWind Management Console in Access rights tab you have allow the used interfaces.
Version 5.6@ziz (staff) wrote:Which StarWind version are you using?
NoName wrote:Ок. It works. Thanks.
