install a remote replication by WAN
gabriel l
Wed Feb 09, 2011 4:36 pm
I'm a student in a france company and i must to install a remote replication by WAN with two sites.
I have one VM with windows serveur 2008 and two PC whitch running Starwind.
Can you tell me how to install this network with starwind ? I don't find a doc.
Thu Feb 10, 2011 7:18 am
You cannot replicate from one node to multiple ones at the same time with current version of StarWind...
If you want us to pick up best working scenario please bother yourself to sit down and draw some kind of interconnection diagram of what you want. Visio should work just fine.
gabriel l wrote:Hello,
gabriel l
Thu Feb 10, 2011 2:14 pm
OK. So, i just will wish to create remote replication like starwind site show :
http://www.starwindsoftware.com/feature ... eplication
But i don't find a manuel to explain how to install this feature. Maybe i must install a VPN but i don't know where to start.
Do you have a idea ?
@ziz (staff)
Thu Feb 10, 2011 2:27 pm
You can use VPN, PPTP or IPIP. The both servers should be on the same subnet to be able to see each other.
We do have a manual with step by step description for how to setup a remote replication configuration but it is not available on our website, send me a message with your email and I will send you the above mentioned manual.
Aziz Keissi
Technical Engineer
gabriel l
Thu Feb 10, 2011 3:35 pm
Thaks, i send you my e-mail by private message
Thu Feb 10, 2011 4:06 pm
Please keep us updated about your progress. Thanks!
