starneo wrote:Hi,
I want to set up (my first) Starwind HA Cluster with HyperV.
I have 2 Storages, each with 2 Raids consiting of 12x600GB SAS (15Krpm), overall 24 disks.
I have created 6 Targets in write-back mode, but I do not know if this is a good idea.
What happens when one Node fails? If I understand it right, the data in write-back Cache will not fully synchronised (5000ms expiry).
This will cause data loss, right?
So my question is, is writ-through better in performance/stability (I think VMs do more reading operation than writing?) in a Starwind HA set with a HyperV Cluster?
thanks for answers.
starneo wrote:Thanls for the answer, exectly what I want to know
starneo wrote:Hi,
I now have a new problem.
Over the weekend I have shut down both storages, because they are in a simple office room for the time of installation.
So they just produce heat and its quite unsafe to let them run ...
Today I started the first storage, wait until Starwind Service came up and started the second one.
The first problem I encountered was that all 6 Target where out of sync on both storages.
No problem till now, because there is no data on it. I started a full sync from node A to B (all 6 Targets). The Storages are still syncing (10TB) via 10GBE.
Here are my questions/problems:
Today I want to set up the HyperV Cluster itself, so I thought, no problem, let the storages sync ... But I am not able to connect from my HyperV nodes to the targets that are still syncing! The iSCSI initiator say "the service is not available".
I hope I am doing something wrong, but not being able to use the cluster only because of a full sync is not good for business ...
There I come to the second question, is there a gracefull shutdown available for Starwind? The reason is simple, it is a situation like above, I want to gracefull shut down Storage B, so Storage A knows that it is alone now. Than I want to shutdown Storage A. When starting Storage A, it should now know that it is still alone but don't say me that all targets on it are out of sync (primary and partner targets). Thats the situation I do have now. This situation might also come when doing some maintainance which needs every server to be shut down.
There I come to my 3rd question, what happens if my UPCs fails and both storages crash at the same time?
starneo wrote:thanks for the fast answer - I unterstood that
starneo wrote:I have now esablished the full HyperV Cluster. With it I am doing some testing.
I copied som larger files from a HyperV node lokal disks to a network share on the starwind Storage.
I saw the RAM load grow higher and higher, as the copy job finished the RAM load droped to normal.
I know this has nothing to do with Starwind, but maybe someone could help me.
The problem is, the RAM load will not stop until it reached 100%, and at this point the Storages performance drops extremely.
So I do not want to face some issues with that when the system goes live.
This also happens when copying ISO files from the SCVMM Server to a new VM (normaly I share the ISOs but, you never know :/ )
This whole thing looks like caching or something ...
In "normal" use it does not happen, creating VM, working with it and so on.
(and no I mean not the Starwind Cache)
hopefully some has a idea
